New Tach please help!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2013, 09:05 PM
Ok so I've got a new tach from AutoMeter. I have a question on how to read it. Imagine that the gauge lays out like this:
,,,,|,,,,1,,,,|,,,,2,,,,|,,,,3,,,,|,,,,4,,,, etc...
RPM x1000
The question I have is how do you read the marks before the "1"?
The answer relates in a way to an issue I'm trying to figure out. I've got it hooked up to a 350 SBC that's all internally stock. I noticed that my truck idles at the "1" mark while cold and drops down to between the sixth and seventh mark once warmed up. Once this occurs, my truck begins to vibrate pretty bad and starts making a sound that as of now, no one i have spoken with can figure out what it is. What is the normal idle rpm for a 350 SBC motor?
Old 02-09-2013, 10:04 PM
every hash mark is a 100 rpm. average idle 650 to 750
Old 02-09-2013, 11:03 PM
Ok thank you that's what I needed to know if your answer is right, then my engines is idling at the right rpm level
Old 02-09-2013, 11:59 PM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
Make sure the tach is set to the right cylinder spec. I had an issue once that the tach was set to a 4 cylinder car...throwing my RPM's off a bit.
V6 car tach vs V8 car tach problems recnepswilliams Hotrodding Basics 8 11-25-2010 09:05 PM
Tach fat40 Electrical 2 01-28-2006 07:11 AM
Tach's - R. P. M. AmericanPackMule Hotrodding Basics 25 01-09-2006 10:11 AM
Tach help. Novaman78 Electrical 2 08-14-2004 01:48 PM
need help with a tach JUS10 Electrical 2 03-13-2003 08:59 AM
