Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New TCI 700R Trans Noise?
Old 05-04-2012, 07:38 PM
Hawkfan Hawkfan is offline
Purchased a 700R trans from TCI. The first time I installed it it lasted about 2 miles and totally quit. I had the reccomended fluid and installed to the correct level. I sent it back for warrenty work. I reinstalled it and it went in with no problem. Filled it up per the instructions. Now, I have this high pitch intermittent squeek like something is rubbing in one spot. I double checked my install and it appears to be correct. The only thing I'm not a 100% on is the "In" and "Out" lines from the trans to the trans cooler.
My question is: If the lines are crossed, would it cause issues internally or cause the sound? Or if some one has any ideas as to what may be causing this noise, I would appreciate any input you may have.
Thanks
Tinley Park,
ILL
