Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New TCI 700R Trans Noise?
Old 05-05-2012, 10:20 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by Hawkfan
I'm not seeing a TV cable on this set up. The instructions do not reference a TV cable. This an automatic trans. They only discuss TQ end play. Am I missing something?
You mention automatic trans
If you have a 700r4 type of trans, it will have a TV cable , even if it is a constant pressure valve body design unit. The TV cable would provide throttle input to the trans for shift timing and pressure rise of main line oil pressure.
If constant pressure design, the TV cable provides input for shift timing
