New TCI 700R Trans Noise? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2012, 08:38 PM
Purchased a 700R trans from TCI. The first time I installed it it lasted about 2 miles and totally quit. I had the reccomended fluid and installed to the correct level. I sent it back for warrenty work. I reinstalled it and it went in with no problem. Filled it up per the instructions. Now, I have this high pitch intermittent squeek like something is rubbing in one spot. I double checked my install and it appears to be correct. The only thing I'm not a 100% on is the "In" and "Out" lines from the trans to the trans cooler.
My question is: If the lines are crossed, would it cause issues internally or cause the sound? Or if some one has any ideas as to what may be causing this noise, I would appreciate any input you may have.
Thanks
Tinley Park,
ILL
Old 05-04-2012, 09:54 PM
327NUT's Avatar
My first question is....did you do the proper TV adjustment per their instructions before driving the car?
Old 05-04-2012, 10:14 PM
I'm not seeing a TV cable on this set up. The instructions do not reference a TV cable. This an automatic trans. They only discuss TQ end play. Am I missing something?
Old 05-05-2012, 11:20 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You mention automatic trans
If you have a 700r4 type of trans, it will have a TV cable , even if it is a constant pressure valve body design unit. The TV cable would provide throttle input to the trans for shift timing and pressure rise of main line oil pressure.
If constant pressure design, the TV cable provides input for shift timing
th 700r trans tmoetown Transmission - Rearend 2 01-29-2012 02:30 AM
67 Nova Harmonic noise TCI Clip kids 1967 General Rodding Tech 2 11-29-2005 05:05 PM
TCI tranny noise ??? A/G WILLYS Transmission - Rearend 8 10-02-2005 08:59 PM
TCI Trans Crossmember Bolt On for Chevy redsdad Suspension - Brakes - Steering 1 10-23-2004 01:44 PM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 01:03 PM
