new th350 cant get reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2006, 05:41 PM
What should I look for to see why I cant get reverse to work on a th350? Its a new motor and transmission hooked to a hurst pistol grip shifter. It grabs park nuetral 123 fine just no action in reverse. I added 12 qt it has a 2 qt oversize pan and a large cooler. The trans also has a transbrake which is not yet wired with 12 volts just the ground.
Old 05-28-2006, 05:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Some tranz brake valve bodies require you to activate the solenoid for reverse to operate in "R".
Old 05-28-2006, 06:55 PM
Duh
I am charging my battery again , but I bet your 100% right about hitting the button! I forgot you have to do that with some valve bodies with brakes. Thanks! I hope thats it.
th350 has only reverse Merickk Transmission - Rearend 1 01-04-2005 03:07 AM
th350 reverse double apply??? eskoskimo Transmission - Rearend 1 10-11-2004 06:07 AM
th350 - no reverse speedo Introduce Yourself 1 08-10-2004 08:16 AM
TH350 No Reverse jackp Transmission - Rearend 9 02-07-2004 09:49 PM
TH350 Reverse Problems TNEddie Transmission - Rearend 3 02-14-2003 07:27 PM
