Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - new tool from Dremel: the "Stylus"
Old 03-17-2006, 12:25 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Cool new Dremel tool with potential applications to more detailed-oriented work in hotrodding. Available from Amazon.com.
The $69.99 Stylus is designed to be held like a pencil, according to the company. The stylus ships with 25 bits and other accessories, which may be interchanged with other Dremel products, providing the collet is the correct size, the spokeswoman said...
Inside, the Stylus houses a 7.2-volt lithium-ion rechargeable battery, similar to that used inside of a cellular phone. The company didn't indicate the size of the Li-ion cell, but said that it would hold a charge for two years.
In addition to the standard power switch, the Dremel Stylus also includes a rotary dial to control the speed of the bit,which can spin from 5,000 to 25,000 RPM.
