New tool for my shop!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2008, 10:32 PM
life is a temporary assignment
I just finished building a 20 ton metal brake.Boy this will come in handy.I have less then $200.00 dollars in it.It is air over hyd.I bent some 5/16, worked great. Going to build a roller next.
ID:	27438   Click image for larger version
ID:	27439   Click image for larger version
Old 01-26-2008, 10:51 PM
powerrodsmike's Avatar
Wiki Edits: 161
You can make most anything that you'd need on a car with that brake.
Good one!
later, mikey
BE different....ACT normal.
Old 01-27-2008, 06:25 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Cool.
A friend had one built way back with a gas motor & pump.
I can't see what the lower die is made from? Angle iron? He would sometimes want a crisper bend in light gauge; he had 2 pieces of flat stock and placed one in first, then let the 2nd one slide down onto the first one in a herringbone style. That gave him a sharp 90* instead of the angle iron that was used for thick stuff.
Old 01-27-2008, 06:44 AM
cboy's Avatar
Last journal entry: Finished
Except fuzzy dice!
(BTW, nice work New Interiors. How 'bout a short materials list.)
Always learning...and sharing what I've learned.
Old 01-27-2008, 07:29 AM
leldai73's Avatar
Its just metal,you're the boss
nice work, thanks for sharing. I've been wanting to build just such a set up, but I'm thinking my best bet is going to be making a unit that sits on my existing hydraulic press, save on material costs and space. are the dies heat treated at all?
Old 01-27-2008, 10:28 AM
Youngster's Avatar
That's awesome. Your going to wonder how you ever got along without it. I copied the one Northern Hydr. sells for my Hydr. press. I found that bby going to couple of shops with huge break presses, I could get short sections of dies. I got everything from a chisel edge to a goose neck. They only charged me a few $$ each.
Youngster
Old 01-27-2008, 11:29 AM
cboy, I will put together a material list soon.The bottom die is an angle iron.And the top is a piece of square bar.There is a couple things I would do different.But it does work great.
Old 01-27-2008, 11:33 AM
Wiki Edits: 161
Youngster
That is a great suggestion, I know where I'm going on Monday
Mikey
Old 01-27-2008, 12:21 PM
Built sounds so much better than bought! Just has a nice ring to it.
Old 01-27-2008, 01:05 PM
Don't have much money!! So I make alot of things myself.And I like to say I made it.It's hard to get just what you want today!!!(and last)It will come in handy for all kind of brackets.
Old 01-27-2008, 03:13 PM
Yeah and how many times has someone said to you "nice job" when you show them something you bought. Good job you have something there you can take pride in.
Old 01-27-2008, 03:46 PM
I know what you mean!! Thanks for complement. I will be building a roller next.I want to build another home made car,But out of steel this time.since steel is my trade.Plus my buddy Iron man Joe's want's to see what I can do.So I may give him a run for his money.LOL But I need to finish my coupe first.
Opening a body shop in Maryland daveh Hotrodders' Lounge 2 03-22-2006 08:46 PM
looking for info on opening a shop in a small town rb8179 Hotrodders' Lounge 15 02-25-2006 05:03 PM
Opening a Hot Rod/Custom Car Shop 70chevy Garage - Tools 45 07-10-2005 03:19 AM
push rod clearance tool lanierledford Engine 1 07-04-2005 08:32 PM
Home Mechanic's Tool Guide bigbird Hotrodders' Lounge 3 08-24-2004 10:06 PM
