New torque converter selection . - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2012, 09:42 PM
blacklabzeke's Avatar
I need to replace the TC in my 88 full size Blazer with a 700r4 with some mods and upgrades on internals. The engine is stock, 33" tires and I do some LIGHT towing. I am fed up with the quality control and cheap parts used in rebuilts (been through 3 in about 30K miles) The original TC had a DEF code which I beleive is 1600 stall with lockup and it lasted 215K before a total redo on the vehicle. I am looking for suggestions on a NEW TC that is reasonably priced that will last. I need to get this vehicle on the road due to losing my other car to hurricane Sandy. I am not running crazy horsepower through it and don't beat on the truck. Just looking for quality! Thanks in advance.
Old 11-23-2012, 12:45 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Always had good luck with Hughes products.. I bet they could set you up with a good TC. Even a lower stall if needed- towing type converter.
Some aftermarket brands used to offer TCs for these transmixers that did not have a clutch. You want the clutch.
Old 11-23-2012, 12:54 PM
malc's Avatar
Living At The Speed Of Life
I installed a TCI lockup in my Camaro, rushed the job and didīnt prefill the converter.
It trashed pretty quick.
I now have a B-M, itīs lasted quite a long time.
Old 11-23-2012, 06:03 PM
I will give Hughes a call and see what they have to offer. Thanks.
4l60e torque converter clutch torque capacity rx191 Transmission - Rearend 1 04-05-2011 05:03 AM
Torque Converter to Flexplate Torque Spec. Needed - 2004R Zeeb Transmission - Rearend 1 05-26-2010 07:47 AM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 08:52 PM
Torque converter selection raidmagic Transmission - Rearend 3 02-22-2005 10:08 AM
Torque converter selection 1meancuda Transmission - Rearend 3 10-23-2002 09:00 PM
