new tranny and engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2003, 07:54 PM
Dreadlord's Avatar
Proficient Motorsports - Owner
Last journal entry: The Trucks Redemption
im planning on replacing my v6 with a 350 and my automatic tranny with a manual. would i have to replace teh rearend to so it will hold more torque and rpms.
Old 12-03-2003, 12:04 AM
billman's Avatar
It is very likely that you will have to change the gear ratio in the rearend. Most automatic cars use a very high gear, such as 2.98:1 or higher (lower numerically). If you put a manual tranny on that you're going to be slipping the clutch to 30 mph. and running on the freeway in second gear. I don't know what you have so I can't tell you if you should change the housing or carrier.
Other than that, watch the frame side engine mounts, they are probably different than the V8. Easily scrounged at the local wrecking yard. The throttle linkage may have to be changed to V8 also.
Good luck!
