New U-Joints have heavy resistance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2012, 11:37 AM
67MercCat's Avatar
Junkyard Dog
Hey guys I just pressed in some new u-joints into my driveshaft and I noticed that the joints are really stiff when I try to rotate the joint. Should I remove the snap rings and file them down or is it supposed to be like that?
Thanks
Old 07-30-2012, 01:45 PM
Richiehd's Avatar
JS-70
Give each side a shot with the hammer. Dont mash it, just a shot. Then they will be fine. Grease em up and put the driveshft back in.
Old 07-30-2012, 03:39 PM
LATECH's Avatar
Last journal entry: New Gas Tank
X 2 with rich. Strike the yoke with a hammer and hold the opposing cross part of the joint, I hold them in my hand. Striking it in this fashion "seats" the caps against the clips and stress relieves the yoke. They will move freely after that. If not, then something is messed up.
Fact is stranger than Fiction
Old 07-30-2012, 04:35 PM
Yep they're right. Just don't do like Little Mike Marlow did and hit your thumb----twice!
Old 07-31-2012, 09:32 AM
67MercCat's Avatar
Junkyard Dog
thx guys, I'm on it.
Old 07-31-2012, 03:52 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X4 Been there.
Cole
Old 08-01-2012, 05:28 AM
Irelands child's Avatar
Then there is that @#$% single needle bearing that flopped and you still put the u-joint together. And yes, that u-joint, in many cases, can be fully assembled with exactly that tight effect. You don't need to know why I know this
driveshaft, ujoints
Plug Wire resistance. DoubleVision Engine 8 03-02-2012 05:40 PM
How is resistivity different from resistance? maha22 Electrical 1 08-12-2010 11:15 AM
Resistance Wire VETTEPERSON Electrical 23 08-12-2010 08:21 AM
Ignition resistance radracer43 Electrical 0 03-13-2005 11:58 AM
Sparkplug wire resistance vegahigh Engine 10 09-30-2004 09:40 PM
