New to uphostery and need help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2013, 08:26 PM
I want to learn how to upholster (trim) and recently started a evening class at the local high school to learn some of the basics, unfortunaley, it's a class mostly designed for women who want to make their own clothes... but I am learning. Now to the help I'm looking for: I was given a Singer 111W155 machine that I was told works well but it needs a new cog wheel (?) belt put on. I have the belt but can't figure out how much of the machine needs to come apart to be able to put the belt on. It appears to me that the main shaft needs to come out and I don't have a clue as to how to do that. Any guideance would be appreciated. I have searched online, I've looked at the Army and Air Force manuals and still can't seem to find any directions to help me.
Thanks in advance, Fast Jimmy.
Old 02-13-2013, 09:04 PM
I learned alot from watching the How To DVD's from Sid Chavers. Best $$ I spent and very informative.
Old 02-14-2013, 07:29 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I suggest this to everyone who gets a used industrial sewing machine. Don't try to do this yourself, changing that belt is not easy. Take it to a professional sewing machine mechanic, have him set the timing, set the tensions, and check the machine out for worn or broken parts. Have him put the belt on at the same time. It will be the best money you ever spent. That way you start out with the machine sewing like it should right from the git-go. Also, if you got any thread with it use that thread for practice only. Why ruin a project by using bad thread?
If you really want to ignore this advice and try to do it yourself, check out page 12 of this service manual: http://parts.singerco.com/IPsvcManuals/211W155.pdf This is a 211W and not a 111W, but you'll get the idea. If you don't do this correctly, the machine will be out of time and then you have a whole new problem.
Old 02-14-2013, 07:57 AM
adjusted nuts
1-11 w
I second that, total agreement with Dan. Been there and done that
Old 02-14-2013, 08:11 AM
Wiki Edits: 27
Read Dan's info
I don't know if you have been to the interior section here on hotrodders, DanTwoLakes is a professional upholsterer and has posted lots and lots of info here on hotrodders. It would be really nice if the new owners would do an eBook like cBoy's scratch built hotrod. Thanks for all your contributions Dan
Old 02-14-2013, 08:32 PM
Thanks
Thanks for the replies. Dan's response with the 211 info was very helpful. I'v actually looked for a service person by talking with a local trim shop and a shoe repair store. The trim shop guy says he does his own repair work but won't work on anybody else's and the shoe repair guy says his guy won't work on machines that old. I'd rather have an experienced person do it but I may be forced to take it upon myself.
Fast Jimmy
Old 02-15-2013, 02:23 PM
Wiki Edits: 22
Thank you Tim. My opinion is that you can't learn upholstery work with books or pictures, so if I ever do anything like that it will be DVDs. I would also like to do a DVD on the care and feeding of the industrial sewing machine. That one would be first.
Old 02-16-2013, 07:46 AM
AFX's Avatar
AFX AFX is offline
You can find repair men going into craigslist " industrial sewing" and see if someone has more than one machine in seperate ads. Alot of repair men fix old or broken machines and sell them for decent profit.
Old 02-22-2013, 07:29 AM
Thanks to Dan for all the time he puts into helping others. I am just starting to tackle this sewing thing. My brothers hot rod shop gave me an old Consew and I am having it gone through so I don't start with something that has a problem. He says he will "port and polish" parts of the machine. Is he taking advantage of a total beginner? Seems like a stand-up guy. Steve
Old 02-22-2013, 12:59 PM
Wiki Edits: 22
I think he was just referring to checking and cleaning the machine. There's no "port and polish" that needs to be done to any sewing machine parts.
Old 02-22-2013, 04:32 PM
adjusted nuts
I have never heard of port and polish in a sewing machine, but some times they will polish the Hook so there is no burrs and sharp places on the Hook and thread guides.
Old 02-24-2013, 10:53 AM
repairman
Well, I've found a repairman that makes service calls and he'll be in town next week and will look my 111W155 over and put the timing belt on for me. He says he's worked on this model before and sounded knowledgeable.
Thanks for the advice. Fast Jimmy
Old 02-24-2013, 03:56 PM
I'll let you know how it turns out. The guy does good work,( from references), so I hope everything works out. We will see how the "port and polish" works out. Ha Ha. Steve
Old 02-27-2013, 03:17 PM
repairman
So I had timing belt installed and my machine looked over and adjusted by a repairman who's main job is maintaining machines for an industrial sewing manufacturer. He was kind enough to walk me through the whole process and described everything he was doing and why it needed to be that way. Then he ran some test samples and showed me what adjustments affected the stitches and how it affected them. It was well worth the effort to find this guy and well worth the cost. Now I can try to sew. Fast Jimmy
Old 02-27-2013, 07:39 PM
adjusted nuts
I knew thats what you needed. I used to have a repairman stop by about every 6 months for about 10 years, thats how I learned to repair and set the timing on any machine , so always ask him questions. Glad Dan and I could help
Protect your uphostery with slip covers cboy Interior 3 03-04-2004 07:46 PM
