The New Virtual Kustomz Thread! - Page 12 - Hot Rod Forum : Hotrodders Bulletin Board
  #166 (permalink)
Old 08-02-2005, 01:06 PM
crazygutgut's Avatar
I wanted an egg-salad sandwich
Originally Posted by grouch
I've looked at this thing too long. Attached is my hack job on an image to try out a new grill for my Olds. What do you think? Is it too fugly to rescue? Potentially better than stock? Too badly drawn to tell?
I like it!, maybe go with a full oval like the vette and that "rare" olds f-88?
that front would look WAY cooler on your car, than on the f88
heres a vette
  #167 (permalink)
Old 08-02-2005, 01:09 PM
That shadow is from the little yellow lifeguard truck that yours is overlaying. A proper build-up of layers would have been: the beach, the driver's side exhaust, the surfboard, custom wheels, the truck, the passenger's side exhaust. I use so many layers trying to get something to work that the file ends up over 2MB even though the exported JPEG is only 56K or so.
Layers are the best way to go! I often use 10-20 in my chops. I usually try to have every element on its own layer, you get a lot mor control that way, also you can experiment with each part and not mess up the whole thing..
grouch your still using gimp?
  #168 (permalink)
Old 08-02-2005, 08:07 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Funny you should mention an oval; the way I came up with that previous grill was to create a new layer overlaying half of a big grill. See attached.
Yes, I use gimp.
  #169 (permalink)
Old 08-02-2005, 09:14 PM
grouch that looks way better than a half oval!! get some vette bumpers and that thing would look sick!!
Bonuts. 2 versions, same paint scheme as the S10, tried to get as close to the S10's colors as I could, gave you a gas cap, closed the trunk, nothing fancy... hope the wife will see your vision now...
  #170 (permalink)
Old 08-02-2005, 10:17 PM
bonuts's Avatar
Got Ouzo for touzo
CrazyGG that is HOT, love it. Just need to do some convincing and thats what I'm gonna do. Thanks dude.
Hey side note, I knew I had some version of photoshop, its Version 6. Is it any good for this stuff or no?
bonuts
  #171 (permalink)
Old 08-02-2005, 10:28 PM
1Fast65Elky's Avatar
Left Nut, Right Nut....Squish!
yep ps6 is good,
Thats what I've been using since I formatted week or two ago..
(your latest nova pic by me was made with ps6)
ps7 has more filters, but I think you can download plugins or somethin if needed....all the basic good stuff is there on 6 though.
  #172 (permalink)
Old 08-02-2005, 10:32 PM
Bonuts, 6 is fine! I just did your car in 5!! Elkys right, 7 and CS have way more filters and bells and whistles, but all the basics have been the same since Pshop4. you can download filters for all of them, but i think pshop 6 filters will be harder to find now that it is 2 versions behind....
  #173 (permalink)
Old 08-02-2005, 10:37 PM
bonuts's Avatar
Got Ouzo for touzo
I guess its time for me to upload it, and give this a try.
bonuts
  #174 (permalink)
Old 08-04-2005, 11:26 PM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
Hey Nightrider!
Heres a caddy done for ya. hows that for a shade of red?
Brad
Name:	blah blah blah.jpg
  #175 (permalink)
Old 08-05-2005, 08:58 AM
Brad, thats cool! musta been a pain coloring around all that chrome.. I would have ended up de-chroming it!!
  #176 (permalink)
Old 08-05-2005, 09:55 AM
Gone fishin'
Wiki Edits: 2
Thanks man,Ive been talking to Nightrider through PMs for a while. I tried to give a candy apple red, I didn't know what flames to put on or dechroming it or lowering it any. I figured out how to use the mask on PS. It makes it a TON easier for us guys with laptops!
Brad
  #177 (permalink)
Old 08-05-2005, 10:43 AM
when you do the color, are you using transparency? Or do you use layer adjustments like "overlay" and "Hardlight". it looks like you do the color in its own layer, each layer has an adjustment, which defaults to "normal" overlay will keep the colors hue, but add transparency to the color. when placing a color over white, its hard to get metallic, what you might try (and this is tricky and hard to explain). but you can create a metallic layer, basically you need a metallic sample (image search this) then make the metallic layer the same shape as the color layer, over lay the metallic on the car, then the color on the metallic. I have found it is much easier to get a metallic look when you put a light color over dark... Hope that helps!!
  #178 (permalink)
Old 08-05-2005, 11:32 AM
Gone fishin'
Wiki Edits: 2
Ive just been doing the desaturate and then put a new layer of color on top and adjust the transperancy til I get the color I want. I never thought of doing the metallic like that, Ill have to try that later when I play around with it next time.Thanks dude
Brad
  #179 (permalink)
Old 08-05-2005, 12:55 PM
1300
Brad
How about something like that? and what if add small flames trailing any kind of a chrome things?
  #180 (permalink)
Old 08-05-2005, 12:59 PM
Gone fishin'
Wiki Edits: 2
Looks good nightrider, Id try flames coming from the front or coming from the scoop on the side.
Brad
Virtual Kustomz Thread 9/26/02 - 7/15/05 R.I.P crazygutgut Hot Rod Art 0 07-15-2005 10:02 AM
