The New Virtual Kustomz Thread! - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 07-20-2005, 10:03 PM
crazygutgut's Avatar
I wanted an egg-salad sandwich
dang grouch thats scary!!!
okay mike heres your flat black with lime, sorry no caps, but I gave you a speed shop logo!!!
  #62 (permalink)
Old 07-20-2005, 10:14 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Hey, I never claimed to be an artist! You should've seen the one that was sectioned, dropped and chopped.
That looks cool with the gangster walls. What about a cover on the bed?
It would be nice to have some stock images of wheels and things to be scaled and pasted.
  #63 (permalink)
Old 07-20-2005, 10:32 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
THAT IS WICKED!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks Paul, I love it, might use it as my avi
Mike
  #64 (permalink)
Old 07-20-2005, 10:56 PM
Hey Grouch !!I actually meant that as a compliment!! It was so good looking it was scary!!!!
Ron heres yours...you now all you need now is to weld off those doors and put the big O1 on the side....
Last edited by crazygutgut; 07-21-2005 at 10:04 PM. Reason: cleaned up those SPOTS!!!
  #65 (permalink)
Old 07-20-2005, 11:00 PM
grouch..use GOOGLE image search... for rons car I typed "weld draglite" got a ton of hits...
I do very well finding stuff through that,also there are a handfull of car sites that have good pix...
  #66 (permalink)
Old 07-21-2005, 01:14 AM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
Here ya go mike, I put some flames on it for ya. I didn't chop it like elky did, I like it better myself without being chopped, and I didn't drop it as much this time. And while I was at it I cleaned up a few things for you, like the box under the truck, and I cleaned out your garage and redecorated it for you.
Brad
  #67 (permalink)
Old 07-21-2005, 01:28 AM
1Fast65Elky's Avatar
Left Nut, Right Nut....Squish!
got ahold of rons malibu.....skew kicks butt!!
Kind of reminds me of a "modern" chevy II...
  #68 (permalink)
Old 07-21-2005, 09:18 AM
Mike, I'll try a red/flamed one too.. I still have to squeeze in 8 hours of work too!!
Brad, the poster was a NICE touch
Elky, that skew is SWEEET, nice job on the color too... Did you just lay purple over it? or did you desaturate first, then over lay the purple... it looks like you did the desaturate...
  #69 (permalink)
Old 07-21-2005, 11:09 AM
grouch's Avatar
Wiki Edits: 2
Do you just scale them by eyeball?
  #70 (permalink)
Old 07-21-2005, 11:50 AM
usually its all by eyeball.. with the weld rims, I removed the "extra" stuff around the rim until I had just the "front of the rim" (I removed the stuff zoomed in about 300% and justed used a "non aliased" eraser) then When I had the finished item, I just scaled it down to fit over rons existing rim.. its easier to find a tire with the rims, but I couldnt find any in this case...
this is the image I used for the wheels.. you can see what I erased... Iused these because they have the closet angle to rons tire.. when doing wheels its important to match the angle. if the wheels are off its more noticable, than if you missed a spot of color...
  #71 (permalink)
Old 07-21-2005, 11:56 AM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
Thanks guys!!! My photochop of my truck sucked, I did the desaturating one but my flat black wasnt really flat....lol....and I didnt mask of properly. Ah well I'll try again.
Brad that's killer! I was gonna show it to my dad but decided not to Take your time crazy, I'm not in a hurry.
Mike
  #72 (permalink)
Old 07-21-2005, 11:58 AM
I used the smudging finger thing and smoothed out the chips/color of it (does the desaturate do the same thing?), while shaving it at the same time..that and a dark blue with some purple and a little cyan in it. I did tint the windows blue, blut it made it look like i just colored the whole thing so i left that out...
  #73 (permalink)
Old 07-21-2005, 12:28 PM
Gone fishin'
Wiki Edits: 2
How about we add some flame window tint to mikes truck? You know, like what my truck has. Ill do that later tonight, I have to go to work now...again
Brad
  #74 (permalink)
Old 07-21-2005, 12:29 PM
elky it looks nice. Desaturate is in "adjustments" what it does is basically turns your picture (or selected item) black and white its much easier to lay a color on TOP of black and white, than say burgundy, like Rons car. I actually forgot to "touch" up the spots on rons car (maybe i'll redo it tonight) For touchups I usually use the "eye dropper". I put the eye dropper near the item I want to touch up to get an accurate color then I brush over it, or use the line tool to touch up.. The trick with the eyedropper is getting the right sample color, and depending on the "quality" of the print you may need to mess with the eyedropper setting... rons picture is high quality so a 5x5 sample would work on his..
  #75 (permalink)
Old 07-21-2005, 12:33 PM
Mike
mike for yours, I desaturated, but also turned the brightness down, since it was more of a flat gray, after desturating... masking is tricky too. you can "cheat" and avoid using the mask by using the polygon lasso tool, just go highlight around the object, then COPY it to another layer, then clean up all the excess with an eraser, I find this method faster and easier than masking.. you can also use the "cleaned up" layer as an overlay for color, once you have cleaned it up, then you can copy that selction to yet another LAYER, use can then fill that with a color or a fade or whatever, then select "overlay" on that layer to put it on the car..
on average I use about 10-15 layers for a chop!!
Virtual Kustomz Thread 9/26/02 - 7/15/05 R.I.P crazygutgut Hot Rod Art 0 07-15-2005 10:02 AM
