new vortec 5.7 99' escalade - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2008, 10:54 AM
Hey guys I just bought a new vortec 350, that was a core at the salvage yard. I removed the plugs and it was spinning pretty freely.
I pulled the pan and everything is intact and looked BRAND NEW, infact All the rods and rod caps had 1-8 etched into them so I'm pretty It's been rebuilt before. The crankshaft looked brand new as well.
I just couldn't figure out why this motor was a core and not good. I ran a compression test before I removed the 062 vortec heads and It was only showing 10-20 PSI on every cylinder...????.... I know it was cold and had no oil in it, but It should still be more then that....Right???
The cylinder walls were all smooth as glass and looked like chrome. Shouldn't they have a crosshatch to them faintly????
I even loosened all the rockers to make sure they didn't have the valves to tight but I still got the same readings for the PSI.
Is it possible that they just didn't hone it properly on the rebuild and it kept the rings from seating???
Old 11-02-2008, 05:08 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
10 - 20 pounds on a compression test sounds pretty miserable alright.
The cylinders would exhibit the crosshatch like you say if it was in fact recently professionally rebuilt.
If the timing chain had slipped a couple of cogs you may have such a late closing intake that you get those dismal compression readings. How sloppy was / is it?
I wouldn't take the numbering on the con rod & caps as a sign that it has been rebuilt. How about fresh stampings on the crank like 010 /010 or something similar indicating it has been reground? Are the bearings GM original and standard size?
All may not be lost, it sounds like you've got a core to work with.
Oh yeah - what kind of ridge do you have at the top of the cylinder? That's a good indicator of wear.
Old 11-03-2008, 04:41 AM
vortec 5.7
Dawg,
No ridge at all, Looks like someone just flatstone honed it and went to far, pistons are slightlt under 4" or right at it and the bore is 4.013, and smooth as glass or chrome. I can't find any stamp on the crank, All the bearings are in great shape, Not a scratch or scuff on them. The crank casting # say's its a steel vette crank so I'd bet its new and not what came in the motor. oh well, I'm gonna take her to +.030 Cross hatch hone and throw it back together,..... with new bearings, ect and F/T pistons
change a 1997 5.7 vortec to TBI ?For propane purposes oakman Engine 7 04-24-2010 10:04 PM
99 chev 5.7 vortec fuel problems??? ron curry Engine 3 06-10-2007 10:07 AM
5.7 Vortec Heads Mustangsaly Engine 4 12-09-2005 07:48 PM
5.7 Vortec Mustangsaly Engine 6 12-07-2005 01:18 PM
1999-2000 Cadillac Escalade 5.7 Vortec Motor?? acr Engine 5 08-04-2005 05:12 AM
