New Water Neck Gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2004, 06:47 AM
18-FEVR's Avatar
I am ready to install a new gasket
with the water neck that goes into the intake. I have cleaned both the bottom flange on the neck and the surface on the intake.
Should I use any kind of sealer with the new gasket ? There was no indication when I removed the neck that any sealer was applied just a make shift gasket someone had cut from a peice of thin cardboard material.
Thank's for any input you may have.
Old 12-28-2004, 07:13 AM
johnsongrass1's Avatar
Race it, Don't rice it!
NO sealer needed. You can use a little RTV if you chose. No gaskets besides head gaskets will I use a sealer on.
Old 12-28-2004, 07:25 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
water neck
If it is a chrome one, I would certainly use rtv.
Old 12-28-2004, 07:47 AM
18-FEVR's Avatar
Re: water neck
It's chrome. Would permatex be Ok to use?
Old 12-28-2004, 08:21 AM
Same thing. IF you make sure the flange is flat and clean you won't need it.
Old 12-28-2004, 09:26 AM
18-FEVR's Avatar
Thank's johnson
The flange is clean and flat. I'll nix the permatex then.
I always felt if you have a good quality gasket and the parts you are gasketing are clean & flat you shouldn't have goop it up with a sealer.
Old 12-28-2004, 09:53 AM
Agree. I hate sillicone. Smells bad too.
