New welder - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-27-2007, 10:11 PM
life is a temporary assignment
There are so many weld techniques it would take a while to explain.Oldred is right,But like he say's mainly on panel use the spot weld.I know how to do it,And I have never had a problem,The key to a good weld is penetration,And years of welding.
P.S. I'm not tring to get in a welding contest with anyone just tring to help.
  #17 (permalink)
Old 12-28-2007, 08:13 AM
Mrwood's Avatar
Last journal entry: My 1962 Falcon
re: New welder
Well i tried some different settings, and got a better weld than my first try. But my feed seems to stop and go, so it makes it hard to keep a weld going. Maybe i have my wire adjuster to tight, or something else is wrong. Sure is going to take me some time to get it set up right. I will post a pic of what my last weld looks like, and then go from there. Thanks again for all the help.
  #18 (permalink)
Old 12-28-2007, 08:35 AM
Don't put it to tight.Hold the wire,And start to tighten down a little to it start's to push the wire,while you hold a little tension on the wire.If you put it to tight it will scar the wire and every time it passes through the tip,It will stop.And go.Hope this helps you.And also don't put it to tight were it holds the wire in the box.On the spool.
  #19 (permalink)
Old 12-28-2007, 08:44 AM
Mrwood's Avatar
re: New welder
I will go back out and check that, may be my problem. Hear is a pic of my second time with this welder on 16 gauge. Its ok to have fun with this, as i know it looks like****. But i will keep trying, but i got good penetration. I will try to get a better closeup, as these dont look good.
ID:	26472   Click image for larger version
  #20 (permalink)
Old 12-28-2007, 08:56 AM
That's not bad at all,Try coming in and out of the puddle a little,Not much!! You may be letting it build up a little to much.
  #21 (permalink)
Old 12-28-2007, 09:30 AM
Mrwood's Avatar
re: New welder
Ok ill try that. I just went out and adjusted the tension on my wire, and that was what causing my wire to stop and go on me, so i should get a better weld now. Im trying to learn how to weld in a C motion, but i think it will take some time. Right now i just want to get a good clean weld and ill be happy.
  #22 (permalink)
Old 12-28-2007, 09:37 AM
You don't have to work and a c motion,With a mig,If you go in and out,Just a little bit,Not much.It may be a little easier for you.Try that and post some pics,And i will help you out. c motion is good to learn but it will come.
  #23 (permalink)
Old 12-28-2007, 10:02 AM
Mrwood's Avatar
re: New welder
What kind of angle should i hold my gun, i may be holding it to high, but dont know. I think ill have this down in a couple of more days. Ill keep trying till im happy with it, but im having fun right now. You guys are sure a big help to me, as its not easy to weld when your almost blind, but im happy with what i have done so far with this new welder. I did notice a little slag, so may have to turn my gauge up a little. Im done for today, time to take my medicine, but will be back at it tomorrow ok. Thanks again.
  #24 (permalink)
Old 12-28-2007, 10:12 AM
First off take care of your self.Play with the angle a little,And it will come to you.Lots of practice, And you will be a pro!! It takes time.If I was there it would be a lot easier for me to show you.I showed my son when he was about 10 yrs old.I had to stop,he was getting to good. LOL He pick it up very fast.If I could see you welding I could tell you what you are doing wrong.But so far I think you are on your way!!!
  #25 (permalink)
Old 12-28-2007, 10:39 AM
What you are seeing is the Silicon that is used as a de-oxidizer in the wire composition to help it to weld over impurities in the base metal such as metal oxides and millscale, this is harmless and normal. Silicon and Manganese are used as de-oxidizers and while the Manganese simply becomes part of the weld the Silicon will solidify on top of the bead sort of like small areas of amber colored glass. To set the gas flow it is best to turn the flow down until you start getting porosity in the weld while welding on a piece of scrap, then increase the flow until the porosity just disappears then add a couple of CFH(or PSI depending on your gauge scale). Turning up the flow more than what is needed to prevent porosity will not hurt anything except your wallet as it will waste gas but it will not help anything either. It is VERY common advice, even in a lot of welding manuals, to turn up the flow if there is a draft in order to prevent porosity but the fact is this rarely if ever helps much and the solution to draft problems is to remove the draft by avoiding trying to weld outdoors, closing doors, turning off fans, setting up "wind breaks", etc. The flaw to that advice about increasing flow is that it assumes the shielding gas is being blown away but that is not the problem, if the breeze is strong enough to actually blow away the gas then not much of anything is going to help except eliminating the breeze. The real problem is that in a draft the shielding gas will become contaminated with atmospheric gases and will lose it's ability to shield the weld puddle even though it still may cover it and turning up the flow is not going to do much to solve that problem.
  #26 (permalink)
Old 12-28-2007, 10:54 AM
That's good information Oldred!!I can tell you have been around,
  #27 (permalink)
Old 12-28-2007, 11:18 AM
Mrwood's Avatar
re: New welder
Well ill just keep on welding, and ill catch on before long. I have already had enough help to get me started, so now its just practice. Ill post some more photos in the next couple of days to see if i have improved at all. This will give you all a rest before you cut me off.LOL
  #28 (permalink)
Old 12-30-2007, 12:49 PM
Mrwood's Avatar
re: New welding photos
Ok i tried some new welds. Let me know what you think, as i have alot to learn. If these dont show up good enough then check my Photo Album. But please give me some feedback. I am getting good penetration, but would like to know how to flatten my welds out a little more so they are not to high. But they hold good.
ID:	26566   Click image for larger version
ID:	26567   Click image for larger version
  #29 (permalink)
Old 12-30-2007, 01:22 PM
The key to a really good looking weld is to move steady, every little flinch or movement will show in the weld bead when you are finished. Just keep practicing and it will soon become easy, I guarantee it!
  #30 (permalink)
Old 12-30-2007, 02:24 PM
Oldred is right the key word is steady!!It does look very good,keep practicing,And most of all have fun.
Welder problem - I think Ripped Body - Exterior 18 02-11-2007 08:41 AM
Welder wiring questions zimaad Garage - Tools 1 01-08-2007 10:22 PM
Anyone Welder shopping? Bruckmans Auto Garage - Tools 7 07-06-2006 02:01 PM
My first post and a welder question Bugs Garage - Tools 17 11-08-2005 02:49 AM
Arc welder ~VS~ Mig Welder ChrisMiddleron Electrical 15 07-08-2003 07:31 AM
