rifraf-On a properly set welder using C/25 the bead is flat and smooth with almost no spatter and penetration is about right where it should be. 20 gauge was developed for very light sheet and C/25 has the best characteristics for that purpose with this wire and is the only shielding gas recommended by the manufacturer. Welding is a lot like painting,that is if you stray from the manufacturers guidelines you do so at your own risk. Now after saying all that I still like to experiment so I tried 100% CO2 and got unsatisfactory results. I have not tried pure argon but I don't think it would work very well either. Most cored wires are a mild steel tube with different metal alloys in powder form contained inside with the fluxing agents just as most alloy steel welding rods contain the metal alloys as a powder in the flux coating. But that is a subject for a different forum. For body work and thin metal parts 20 gauge with C/25 works better than ANY wire I have ever used.
Well I agree with what you say,but I can tell you for certain that the results of argon vs co2 are worlds apart,the argon doesn't have the penetrating ability and thats just the very reason I thought it would be so great on light gauge stuff,plus its smooth,see where Im going with this? The recommended procedures are typically made to suit multiple needs for the masses,but as a welder I know that often times procedures are developed and certified for unique applications,thats why I felt argon would be so good on thin stuff,If I did a lot of thin stuff,I would want any advantage I could get. You never know till ya try,I think it would work outstanding on thin stuff from what I know of it,thats why I would like to see how it works,I would have guessed co2 to be a bad combo.
rifraf-I probably would have tried argon if I had some in the shop,like you say one will never know for sure until they try. The smoothest,easiest welding wire I have ever used is Hobart excell-arc 71 duel shield which runs really good on C/25 almost as good on CO/2 but not very well at all on pure argon. I truly wish they made that stuff in .030 but .045 is the smallest I have seen and that is to big for body work. The makers of 20 gauge sell it to be used on the thinest panels likely to be welded and aim it specifically at body shops and hobbyists so I can only assume that they reccomend C/25 because it is the best choice for that purpose. If you try argon be sure and let us know how it works.
welding wire
Do you think this wire would do a decent job with a Miller 175 MIG?
Do you know a part number? |
20 ga.
firebird red, yes the "20" guage will run on a 175 miller. i have a lincoln "sp175 plus" & this wire runs quite well in it & in my opinion the miller is a better machine. i welded proffessionally for twenty yrs. ( i now work for a welding supply co. & sell welders & mig wire. ) i've run a million miles of many types of mig wire with many different types of gas. 75% argon 25% co2 is the gas that should be used with "20 ga". the only use i know of for pure argon while mig welding is for aluminum. another hint for all you guys when running "20 ga." or solid wire, co2 is ok for running hot on heavy material but it still makes for bad splatter & doesn't run well at cooler temps. on lighter material like most of us are using on our car projects. i know it's cheaper, but if things are that tight why are you hot rod building anyway!?!?
So this cored wire used with C25 gas...
Do you used it DCEP or DCEN? Has anyone found an online seller? |
I tried the "Twenty Gauge" this past week repairing floor pans in a '54 F-100. I have a Lincoln 175 Plus mig and used the 75/25 mix. This wire is awesome! I have done quite a bit of welding over the years but am fairly new to mig and this stuff makes even a "so-so" welder look like a pro. I bought mine in Hammond La. 10 lb. spool ran $59.90 tax included. Give it a try, I believe you will like it.
new welding wire
Hey guys,
I went looking for that new 20ga wire, it was hard to find, but I finally managed to get 2 10# rolls. If you like it and want some you better get it because I was told it has been discontinued. The Harris distributer in Houston had 9 boxes when I order mine a couple of weeks ago. |
risaacp- I cannot for the life of me imagine why they would drop something that works this good--BUT, I have noticed that the link to the 20 ga. site appears to be dead! I hope its not true but it looks like it may be.
oldred,
Thats what the rep said, must not have caught on or wasn't advertised well enough. If you want some you better get on the stick!! |
20 gauge
they still show the 20 gauge on the j.w. harris website. if they really are dropping it, i'm going to buy up all i can.
btw i also encourage all you guys to go to the j.w. harris site & contact them & let them know how much you like the wire. tell them to advertise in the rod magazines. jwharris.com Last edited by bluechev; 11-26-2004 at 08:44 AM. |
Hi,
I bought 2 10lb spools and 1 small spool about a month a ago. I havent had a chance to try it yet, but i hope it not decontinuied (based on what ive learned here). Please post if you learn any thing on its availabity. Has any ever used siicon bronze for mig on body panels? I have used it for TIG welding on panels and its super. I bought some for mig but havent tried it yet . (if you get the impression Im kinda lazy you may be right!) Thanks Jeff |
