new wire harness. installing killswitches now - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2009, 11:34 AM
elcaminodragster's Avatar
70 El Camino aka FRANKENSTEIN
Well I just installed a new AAW wire harness. I used the dash ignition switch instead of the column. I've never used a dash switch before. I am wanting to kill the started from turning and kill power to the dist.
I have an HEI dist. I'm most positive I'm correct on where to install the kill switch for the dist. I'm not sure about the starter tho.
Here are the full schematics. . . The yellow arrows are where I think I would install the kill switches. Am I correct???
Last edited by elcaminodragster; 02-06-2009 at 11:48 AM. Reason: forgot the pics lol
Old 02-06-2009, 01:29 PM
302 Z28's Avatar
Wow that is huge picure you posted, I have two 19" monitors and it still does not fit.
Yes, that looks like it will do it. You could use either a double pole double throw switch or use a double pole relay and a single pole switch.
Vince
Old 02-06-2009, 06:38 PM
Sorry about the size of the pics. I had to use my dads camera I couldn't find mine. I didn't want to change the settings on his camera. . . Hes going blind in his old age lol.
Anyway. . . dubble pole dubble switch dub bubble relay bubble duble. . .
You lost me there lol. Double pole double throw meaning an on off on switch?
Could a normal on off switch work???
I want one switch for the starter and one switch for the dist.
Old 02-06-2009, 08:11 PM
Okay I've done a bit of research on kill switches. I found I can install a simple on off switch for the coil feed.
As for the starter a simple switch doesn't seem like a good idea
I found you need a relay and the switch to kill the starter. I know the type of relay I need. I'm still unclear as to the type of switch but I'm guessing an on off switch. I don't know how to hook up the relay tho. Which connection goes to what???
Old 02-07-2009, 05:07 PM
302 Z28's Avatar
Normal on-off switch. I assumed you wanted one switch for both functions.
Vince
Old 02-07-2009, 06:02 PM
Vince
So how do I connect a Bosh relay for the kill switch for the starter???
Or do I just simply put in a on off switch???
Old 02-07-2009, 06:07 PM
kleen56's Avatar
This doesn't have anything to do with wiring in a kill switch, but in addition to the switches, I always use a battery cutoff switch. There are several types out there. Avoid the cheap ones with the removal red handle. Anyways, they come in handy because you can flip the switch and all electrical is dead. It saves you from pulling the cables everytime whenever your doing electrical work. Just my two cents.
Ed
wire harness removal 1badbird89 Electrical 8 12-22-2007 11:57 AM
Disconnecting Original Wire Harness mynovacane Electrical 4 07-18-2007 05:12 AM
Seek opinion of KwikWire 21 cct wire harness jpd37 Electrical 15 08-01-2006 10:42 AM
wire harness for 49 chevy pickup 49dream Electrical 4 08-18-2004 04:53 AM
One wire or three wire? Screwy Lewy Electrical 0 06-30-2003 04:33 PM
