new383ci dyno hp is low - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2006, 07:12 AM
roy383ci's Avatar
a friend of mine has this combo and the power he got wasnt wath he tought
265.2 PK 434nm
chevy 383 4bolt 0.30 overbore.gevlakt zero deck (compressie 10.5:1)
trw -34cc flat 2 reliefs
afr "190" 2.02/1.60 68cc
comp cam 292h 244/244@0.50 lift 501/501
mallory ontsteking
weiand xcelerator single plane
holley 750 double pumper
th400 bak met shiftkit en 2800 stall converter
whats wrong whit this combo
give me you idee's please thanks
Old 09-09-2006, 05:08 PM
runn141's Avatar
timing may be way off
Old 09-09-2006, 05:20 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
What does the dyno say???
Sam
Old 09-09-2006, 05:36 PM
Mustangsaly's Avatar
is the single plane intake the right setup for the CR & cam & torq converter ?
theres some veteran/experts on builds and combos that work together on here that will know. I need more knowledge on cam profiles.
Mustangsaly
Old 09-09-2006, 08:44 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
If I am reading what you wrote correctly, I would double check your compression ratio. A -34 cc dish in the piston combined with a 68 cc combustion chamber in the head will not give you 10.5-1 comp. ratio. You would be 1.5 to 2 points lower. That would definitely affect power.
Old 09-09-2006, 09:06 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Im assuming you have headers? Is this a chassis dyno? I prefer the Edel performer RPM intake. Like others stated ign timing could be off.
Old 09-10-2006, 06:33 AM
We build quite a few circle track engines and street performance engines and most are the 383's here is a link to one we did 2 years ago using the AFR's and this engine was dynoed http://www.chevelles.com/forums/show...highlight=DYNO
and we have also bult a few engines using the the Vortec heads with similar results and I see your cam is a 292 ADV. duration which is a lot bigger then I would use and whats your lobe sep on that cam and see if you cam find out what is the duration at .200 ??
Here is a pic before going on the dyno
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Low vacuum the culpit? juiced66malibu General Rodding Tech 1 09-06-2005 09:52 PM
Looking for a GREAT Dyno in So CA? eric n Engine 4 10-28-2003 10:44 AM
A few changes to 540 hp carcraft buildup... what kind of hp loss? guesstimates please elukas Engine 16 08-07-2003 07:54 PM
