newb question about a th400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2007, 07:01 PM
I put a motor in my truck a few weeks ago, and I pulled it with the torque converter. I accidentally spilled the fluid that was in the torque converter. I then put the new motor in, and I forgot to pour fluid in the torque converter. Now the tranny on my truck barely works. I am flushing the tranny and putting some lucas no slip in, but is there any way to get fluid in the torque converter? or do I gotta pull the tranny and pour some in? Thanks
Old 03-24-2007, 07:12 PM
DeathRattle's Avatar
Some Punk Kid
What do you mean by barely works?
did you install the converter by itself or still on back of the flexplate?
Old 03-24-2007, 07:17 PM
I installed it on the back of the flex plate. By barely works, I mean that it doesn't shift into gear half the time, and it when it catches, it is at high rpm.
Old 03-24-2007, 07:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
if you installed the engine and trans together while the torque converter was bolted to the flexplate...... the pump in the t-400 may be junk now.
Is the trans full of fluid?
The trans fills the converter when the engine is running. The converter has constant full of fluid inside when the converter turns the pump.
Old 03-24-2007, 07:35 PM
I had the tranny in the truck when I put the motor in with the torque converter. I have no idea how to change the pump, but I am gonna put new fluid in it, and some lucas oil and hope it works.
Some Punk Kid
when you put the converter on you have to push and turn and push and turn till it sits just right(engaged on pump properly).
If not like crosley said, good chance you trashed the pump.
This may help.
http://www.partshp.com/ConverterInstructions.htm
Old 03-24-2007, 09:48 PM
chevymastermind's Avatar
drive it like you stole it!
Last journal entry: engine
uuuuuuum why would the pump be junk because i just did the same to my car. i think one of you sayed that the oil will go into the converter on my post. what i did was pushed the converter into thetrans then bolted the tranny to the engine block and i had to slide the tourque converter about 1/4 inch out to meet up to the flexplate! and i bolted the converter to the flexplate. then installed the two. but mine was a Th-350 if that makes a diference?
Old 03-24-2007, 10:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Re-read all of the posts , you will see the fellow did not install the converter as you posted you installed your converter
Old 03-28-2007, 12:53 PM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
I learned this mistake the hard and expensive way,, My son installed the tranny in the car, and didn't make sure the converter was engaged to the pump, and when bolting up the tranny to the bell housing,, he couldn't figure out why the bolts tightened up before it touched the bell housing,, so he forced them,,, I had to tear it all out and buy a new pump,, it just slides in about 1/4 inch or so, to meet the flex plate, but it definately has to be engaged, or its trash,,
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
I have a TH400 question carnuck Transmission - Rearend 2 05-31-2006 07:25 AM
TH400 to 4L60e 1939P7 Transmission - Rearend 7 12-22-2005 08:18 PM
nitrous 69BiRd Engine 2 11-28-2003 11:33 PM
