newbee question about 383 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2006, 08:27 AM
Ok heres the problem:
I'm a new guy on the block when in comes to building a motor, So I've been reading through post after post here on Hotrodders.com. I've found some very useful information. Also reading all the magazines I could get my hands on. Most recently the "500hp under $5000" 383 stroker build in HotRod magazine. I was wondering what kind of hp do you guys think I will make using these:
edelbrock performer intake #2101 &
a set of heads #3986339X
both which were given to me free of charge
also what stroker kit and cam do you guys recommend?
what else would need to be done?
its going in a 1985 swb gmc truck
just a weekend driver 80% strip 20% steet
What I have now is:
sbc350 4 bolt all stock
650 edelbrock carb
rv cam
1 3/4 headers
Sorry for all the questions, i'm pretty interested in learning.
I'm pretty sure I left something out, but any help would greatly be appreciated. Money really isn't an issue but I would like to keep the budget kinda conservative.
Old 08-07-2006, 01:40 PM
I would recomend going with a rotating assem like this (356-B13004E+040)from Jegs.com
As far as a cam, some thing liek a Comp XE284 will work good.
I would ditch the performer and go with a performer rpm, performers are very mild. Considering your 80/20 split in favor of the strip, a performer rpm will make you much more happy.
Your heads are ok castings and are not the best performers. A good set of vortecs will wake your motor up for about $600. If you can spend some more cash on heads I would go with a set of AFR 195s or something like them.
With the right combo you can see 450-525hp for pretty cheap, good luck.
Old 08-11-2006, 11:24 AM
So how about this setup:
vortec heads (found a set for $550)
2800+ stall
3.73 gears
this cam: k12-250-3 (the Comp XE284 kit)
Operating Range: 2300-6500 RPM
Duration Advertised: 284 Intake / 296 Exhaust
Duration @ .050'' Lift: 240 Intake / 246 Exhaust
Valve Lift w/1.5 Rockers: .507'' Intake / .510'' Exhaust
Lobe Separation Angle: 110
this stroker kit: 356-B13004E+040
383ci Rotating Assembly
2-piece rear main seal
4.040'' bore x 3.750'' stroke (.040" overbore)
5.700'' rod length
-18cc inverted dome pistons
5140 steel SIR lightweight connecting rods, std/std cast steel crank, Keith Black hypereutectic pistons, Clevite rod and main bearings, and plasma moly cast iron ring sets
Which intake would you guys recommend:
Edelbrock Super Victor Intake
Edelbrock Performer RPM Air-Gap Intake
Edelbrock Performer RPM Vortec Intake
also is my carb big enough or will i need a 750?
anything i'm leaving out?
Any help would be much appreciated.
thanks in advance!
Old 08-12-2006, 03:30 PM
So..... what do you guys think?
I wanna go ahead and start building, but i wanna make sure i'm headed in the right direction.
Any opinions?
Old 08-14-2006, 09:34 AM
I would go with a 750 carb for sure, and go with a Performer Rpm Air gap. Good luck, I think you have a monster in the making
Old 08-17-2006, 03:03 PM
Mustangsaly's Avatar
stay away from SIR rods. I've heard bad things about SIR Rods, ask machineshop tom on this board about them.
Mustangsaly
383 engine build MANEFRESH2K4 Engine 1 03-11-2006 01:53 PM
350 rebuilt to 383 question jtswilson Engine 17 03-02-2006 10:54 AM
Received my quote to build up a 383 TCAMARO Engine 25 01-07-2005 05:26 PM
need cam suggestions for my 383 build TCAMARO Engine 10 12-23-2004 04:51 PM
383 build novatech Engine 1 03-10-2004 08:06 PM
