Newbie - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 07-14-2011, 12:38 PM
mechdad1's Avatar
Newbie
Hi all, newbie here from Minnesota. Going to enjoy looking through this forum. Have 1963 AMC Rambler 550 Cross Country wagon. 318 904 auto and gm 10 bolt. Will post pictures tonight.
Randy
Old 07-14-2011, 05:41 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site, got any pics ?
Cole
Old 07-14-2011, 07:30 PM
mechdad1's Avatar
Here are a few pictures of my wagon, I am trying to turn it into a street/strip car.
Randy
ID:	56861   Click image for larger version
ID:	56862   Click image for larger version
ID:	56863   Click image for larger version
Old 07-20-2011, 01:44 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Not bad! The only problem with a strip/street car is you end up with something not really good at either. You have to gear it down a good bit to run on the strip (especially 1/8th mile), then it's too low for the street. Using an OD trans helps, since you can have a low rear gear (3.55-3.90) and still have a decent cruise speed without the engine screaming. Just remember to put it in "D" and not "OD" when racing, and make sure the trans is beefed up a bit. That's my two cents worth!
The Rambler makes a great cruiser though. Mine has OD and a Jag rear axle (3.55 gears). Don't know what it would do on the strip, haven't run it. I'm running an EFI six (warmed up AMC/Jeep 4.0L), estimated 220-225 hp (net). Keeps up with traffic, will cruise all day at 80 if I want and still get 20 mpg.
Old 07-20-2011, 03:39 PM
mechdad1's Avatar
I am process of building up a 904 transmission right now with 3000-3500 rpm converter. Also going to run a narrowed 9" with 3.89 gears and ladder bars. To be honest I really don't drive it to far and if we do go any where the longest is maybe 50 miles 1 way so I can sufer with the 3000-3200 rpms down hiway. Going to get trans rebuild done and do some more this winter. Have not decided yet on engine setup. 318/390 stroker or 360/408 stroker or maybe 340/410 stroker right around 10-10.5 compression.
Randy
Old 07-20-2011, 06:48 PM
eloc431962's Avatar
Wiki Edits: 37
Looks good sweet ride.
Cole
Old 07-24-2011, 05:43 PM
farna's Avatar
Wiki Edits: 14
My brother runs a 3000 stall with a 2.73 gear in his 1952 F-2 Ford truck (yes, F-2 -- 3/4 ton model of F-1). Has a 351, C-6, Dodge Diplomat front suspension. It will crank up to 3000 or so rpm pulling a hill, but drops down to 2000 or so when cruising on a flat. 3.89 might be a bit much unless you build a real revver.
Painting Newbie - With a more detailed then the average newbie plan! MKEGuy Body - Exterior 5 05-18-2011 05:38 PM
newbie 57 del rio Introduce Yourself 1 11-06-2007 05:15 AM
newbie houndsplayer70 Introduce Yourself 1 09-16-2007 06:44 PM
newbie michmark Introduce Yourself 1 09-12-2007 05:31 AM
newbie Zoltan Introduce Yourself 2 09-09-2007 12:45 AM
