Newbie with 355 issues. Please no flames
Hello all I've been lurking on the site for quite a while now and have gotten tons of tips and had many problems solved by reading other posts but I haven't been able to pin point this one so I finally registered to post.
Here's a little back ground info. I rebuilt a 350 to and put in my cj-7 a few years back with help and guidance from a mentor/friend of mine. It was my first complete engine build so as I look back I wish some components were researched a little more but hindsight is 20/20. specs 4 bolt main 350 from a 1979 K20 bored .030 over (355 now) stock heads, valve springs, rockers, push rods, and lifters Do NOT have flat top pistons Edelbrock performer intake with performer 1405 600cfm carb. brand new HEI ignition with stock spec ac delco plugs comp cams xe274h cam (230/236) hedman headers timing set to 14 btdc (still learing about total timing so I dunno what its at) problems runs very rich has a bad high rpm studder when "winding it out" I've read many problems of people running rich with the 600 edelbrocks so thats a concern but not first priority. This studder is driving me crazy. It seems like I can run 1st gear up to about 4500 or 5k with plenty of pull but when I go to 2nd it seems to studder very bad until I let off the throttle completely and ease back into it. Im no where near a pro at this but I can't figure it out. Is that valve float, due to stock springs with the aggressive cam? Is the cam too big? Carb too small? I'm lost. Sorry If I used any wrong terminology or sound like just a plain dufus as I'm still learning. Any and all help is greatly appreciated. Luke (CoolhandSr) |
DV is dead nuts on, but I would like to add a bit. Since I'm nver one to leave something alone, I thought I would throw my 2 cents in. If I were doing this, I would think back on what pistons I put in there. Also, shoot out the casting numbers of the heads so we can all see what the chamber size is. They could range anywhere from 58cc to 76cc.
If you remember having dished pistons you could opt for a decent set of heads with 58cc chambers...or at the very least, 64cc. If cost is a prohibitive factor, you could always grab a set of 305 HO heads like the 416s to bump up that compression. Yes, they will require some mods to be able to you use the cam you have. I would also get a dist curve kit and use one silver spring and one blue spring to get mechanical advance all in by roughly 3000 rpm. If you can find someone who knows how, or you can research a way to do it yourself, you could limit the mech advance to about a 14* or 16* swing. @ at 16* swing, you could set your initial timing at 20* , use a 10* vac can to make that 30* and you'll have a WOT timing at about 36* above 3000 rpm. That will give you a nice snappy little SBC. Now, if cost is a huge factor and performance is on the back burner, stab a stock-like cam in there, or the one that DV recommended, and call it a day. |
Replace the cam.Another problem that can happen is "VALVE FLOAT".This can accure at high rpm.High rev's on stock springs and the spring can't control the valve when opening and closing.Worst that can happen is to break a spring and drop a valve into the cyclinder.Good luck.
stefanP |
I'm very late in my response so I apologize for that first and foremost.
Still haven't fixed the issues. It's not my daily driver and my wallet says to wait a bit before purchasing anything not a necessity. The pistons I have are standard pistons so I would assume they are somewhat dished. Where would I find the casting numbers on the heads? What would be a better fix? New heads? New valvetrain? new heads and new valve train? New cam? Another problem I'm having is it seems to be pulling the choke by itself. I've googled it every way to sunday and can't figure that one out. I should have just put a cummins 4bt diesel in in the first place. |
Whoa. You said you used the stock lifters?!?! You should never ever use a flat tappet cam with used lifters. The old lifters are married to the old lobes of the old cam. I think it is safe to say that you probably have irreversibly damaged your cam by reusing the lifters.
But back to DoubleVision's point: I think the easiest thing to do is replace the valve springs. With the correct ones. You can do this with the correct tool without removing the heads. Here are the springs. http://www.compperformancegroupstore...ct_Code=981-16 |
| Help! Newbie first paintjob, acrylic enamel issues | KNanthrup | Body - Exterior | 64 | 05-21-2011 10:55 PM |
| Flames | mopars69 | Hot Rod Art | 2 | 05-15-2008 11:35 PM |
| Flames | Lou Montanti | Introduce Yourself | 3 | 09-10-2005 07:03 PM |
| ss flames | camino_man | Body - Exterior | 2 | 02-29-2004 04:52 PM |
| Flames | KentuckyCamaro | Engine | 6 | 01-15-2003 04:41 PM |
