Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Newbie with head questions
Old 02-04-2013, 05:51 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
I would find the nearest/cheapest flow bench in the area. Not sure what your goal is?What would make a street engine perform the way you like it?Im guessing that 350 HP is in order? All of those heads would work up to 350 horse power.all need to be modifies, so use the best ones based on cfm flow and modify as required for fit and freshen. The vortecs,for example need to be clearanced for over 450 ish lift cams.
