-   -   Newbie Header Exhaust Question (http://www.hotrodders.com/forum/newbie-header-exhaust-question-207007.html)
Bert W 10-13-2011 10:23 AM
Hey Guys! I'm new to the board, but an old uneducated car guy. I used to throw parts on my engines and just live with the output. I am now trying to be a little smarter. I have been reading all of the 307 chevy stuff and plan on rebuilding the original 307 in my 68 C10. I plan to warm it up just a little (305 HO heads, cam, holley 600, Z28 intake, etc.) I believe I should use a small long tube header, correct? What about exhaust, 2.5 or 2.25? I plan on using a flowmaster type mufflers, we used to call them turbo mufflers, maybe an outdated term. I am going to turn them down in front of the rear axle. Will one or two of you gurus point me in the right direction? I hope this info has not been posted to death, if so point me to a link. I love the board so far!
Bert
DoubleVision 10-13-2011 01:36 PM
No problem. I like the little 307`s. They can be made to run strong and blow a 305`s doors off. Flowmasters and Turbo mufflers are totally different.
Flowmasters have no internal packing, instead they have flow directors. Plates in certain places that create sound deflection. That`s how they get that unique sound. Turbo mufflers are still used today and remain popular. In fact, they are all I use. I use to use flowmasters, but I got mellower as I got older and always loved how deep and mellow Turbo mufflers sound, so I went back to them. Turbo mufflers use a S shape tube inside the muffler, the tube has holes punched in them and they use flow directors per turn. They are packed with fiberglass mating to further dampen the sound.
Me? I would use Turbo mufflers, but that`s just me. As for headers a standard set of 1 5/8 primary size with 3 inch collectors will do you fine.
I would use 2.25 diameter pipe with a X pipe installed to balance the flow and helps the sound. I use to let them exit at the axle without tail pipes or turn downs, with Turbo mufflers the sound is wicked deep. Why it`s louder is because under the vehicle creates a echo chamber. I later ran flowmasters this way and it sounded killer. But when I had to get on the interstate my cruise RPM was 2800 RPM and the constant drone drove me crazy in time so I installed turn downs. If your looking for flowmasters I have a good set for sale on the cheap. If your interested let me know.
Bert W 10-13-2011 09:45 PM
Thanks for the reply! That is the kind of info I was looking for. I'll PM you on the flow masters. I might have to try them out.
