when talking about hp you need have a idea of what your goin to do with it,,, st strip straight race,, there is all kinds of way,s to plant hp, all depends on your app,,
| The Following User Says Thank You to s10mikey For This Useful Post: | ||
rock_dog (08-26-2012) | ||
400 hp built good crank, rods piston,s flat top,s,, forged still h beam rod,s for added strenght but your have a good start if you have a steal crank and good heads,, you just half to know wheather you want top end power or bottom end torque,,
Here's my combination and dyno sheet so you can see what it's going to take, cause I ain't there and this is a very healthy and streetable engine. ![]() 331 CI, pump-friendly 9.5:1 CR K&N 14"x4" air filter, Corvette drop base and lid Holley 600 dp, choke horn milled and blended, Primary - 69, Secondary – 74, Squirters - 21 1/2" Aluminum open spacer port matched to manifold, exterior polished Edelbrock Performer RPM, port matched, exterior polished with all extraneous castings and lettering removed Homemade lifter valley splash shield to keep hot oil off manifold bottom Camel hump 1.94/1.50 heads hogged out to 2.02/1.60, pocket ported, port matched, pump-friendly hardened seats, 3-angle valve job Cylinder bores clearanced to unshroud the valves Comp Cams 1.52:1 roller-tip rockers Crane Cam Vintage Muscle 327/350 hp cam, 222 degrees @ 0.05, 0.447" lift (with 1.50 rockers) Doug Thorley headers, dechromed and ceramic-coated 2.5" mandral-bent exhaust (including tips), 2" cross-over just before rear axle DynoMax stainless Ultra Flow mufflers Millerspeed 1-1/2” Gilmer under drive belt drive system Mallory Hyfire IV CD ignition box triggered off Accel points Mallory high voltage chrome coil Mallory spiral-wound coil wire Mallory solid copper plug wires, ends soldered to wires Champion plugs 37 degrees total ignition advance Carter high volume fuel pump Melling high volume oil pump Open breathers Polished aluminum high flow water pump 160-degree thermostat Flex fan with polished aluminum spacer Polished aluminum one-wire 100 amp alternator Header Power Bracket Keisler TKO600 5-Speed Hurst shifter 3.70:1 positraction 225/60/15 Firestone Firehawk SZ50s on 7”-wide Western 30-spoke Turbine Wheels |
| The Following User Says Thank You to toddalin For This Useful Post: | ||
toddalin that engine is making 400 engine hp.the chasis dyno measures rwhp after accessories and driveline take up their share and exhaust too.
rock_dog a 327 does not really make big torque numbers,rev the little engine a bit higher and use a little more rear gear for the torque multiplier in the lower gears.A stock bottom end of a 327 can rev 6500 rpm and last with a good balance.I prefer a solid lifter cam especially for 327s |
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
thanks
What type of cam do yall think, Ive read on the 327 its better to stay around a 218-224 cam instead of going big, They said it makes it a high reving engine and makes better hp than going big on the cam, any truth to this?
And on the pic i posted above, what kind of pistons are those considered? |
copy toddalins build,upgrade carb to 650dp and add 10 degrees of duration to cam and 35 to 50 thou more lift.The duration will give you 700 more rpms which would give you another 30 hp and similar torque.I would say,use a solid lifter cam.
pistons
I didnt see what pistons you used? |
read the first line of his build sheet.
The dyno pull was before the addition of the Millerspeed underdrive system and Car Craft found 10 hp with the Millerspeed a 5,500 RPM. Also we did a bit more intake porting and carb tuning (at 12.8-12.9 A/F, it was a bit rich on the dyno), and I went 1 jet leaner on the secondaries. The RWHP, should now be a bit over 300. Yes, he will need a solid lifter or maybe hydraulic roller cam to get there. I was also able to get rid of the bog spots (~2,200-2,500) by reducing the squirters from 25F/28R to 21F/21R. Because I run a TKO600, these bog spots were just above my 5th-gear cruise RPM (~2,200) and getting rid of them was a real blessing when you get on it in 5th on the freeway. BTW, I would be suprised if a stock 650 dp outflows this modified 600. But without modification, the 650 is probably a good choice.
what,
toddalin said,,,and a dynojet dyno usually reads lower than a mustang chasis dyno. 12.8-12.9 af is great for the street.It would make more power with open exhaust and a little richer. so lets say your engine is 400 ish hp. for sure a good guideline to build 400 hp. My favourite carb for small v-8s like 327s is a 4777 with 4781 base plate and a few tweek s like replaceable air bleeds and minor contouring etc. Its a great share offering your parts list and actual dyno figures. |
| I have a 350 crate engine i want to make atleast 400 hp. | chevydragster83 | Engine | 36 | 08-26-2012 12:47 PM |
| Building a 327, need some pointers | Bad66 | Engine | 10 | 03-25-2011 12:01 PM |
| building a 327 | alleeclan | Engine | 4 | 05-24-2010 07:42 PM |
| Building a 327 I really am.. Slowly | chevy350_Camd | Engine | 2 | 05-15-2008 06:46 AM |
| Building a 283 into a 302 or 327 | trbomike | Engine | 7 | 10-20-2006 03:25 PM |
