Newbie Paint Gun Recomendations - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2006, 06:26 PM
Hi everyone,
I know I need to introduce myself. I will do that shortly. I was recommended to this site from another site and they recommend me coming here for professional advice on paint guns. Im in the market for a paint gun. Nothing I will be using everyday, but mainly for repainting the hood, and maybe other body panels when necessary. Im looking for something inexpensive. I painted a car about 20 years ago with a gun that Im not sure who made, but I remember it was an exact copy of the Binks No.7. I still have the gun but haven't used it in years. I have a small compressor that puts out about 7CFM. I see some opinions of the Harbor Freight HVLP gun that gets good reviews here. (I have been doing some looking around). Im scared to get a HVLP gun since I know my compressor wont keep up, and a guy at work bought one to repaint his snowmobile hood, and he is having all kind of problems with it putting down to much paint. A friend of mine in work that does painting (but don't have time to paint my hood cause he just had a baby) said he never used a HVLP gun, he just uses a regular Binks Gravity Feed. For me, and the occasional amount of time I may actually use it, what would you recommend ? I see the Harbor Freight 43430 gun mentioned here a few times. It is a HVLP gun. Would I be better off as a beginner (with a small compressor CFM) using the 91009 which is just a regular gravity feed type gun, or should I just clean up my old Binks No. 7 Knockoff ???
I will be using it to paint my hood on my van. Its a metallic Blue Basecoat/clearcoat type paint
Thank You
Old 04-28-2006, 07:41 PM
302 Z28's Avatar
Let me be the first to welcme you to this site. There is a great bunch of folks here that are eager to help if you need it.
If I were you I would not use the Binks #7 any longer. After you play with an HVLP and get the feel for it you will swear at your suction guns. The HF 43430 is an excellent inexpensive gun. I think it will work pretty good with your compressor, but you will have to pause intermittently and wait for the compressor to catch up. Once you get the feel for the HVLP gun then you can buy another 43430 and get a 1.6mm or 1.8mm nozzle set for priming. I have several old Binks suction guns including a #69 that I primed and shot lacquer on the 69 Camaro in my avatar. I would never go back to suction guns.
Vince
Old 04-28-2006, 10:21 PM
X711
I think you will find your compressor will leave you little options for guns
that are low cost and that have low cfm requirements. Your average HVLP
gun typically is in the range of 10 to 14cfm at 30psi.
For what you have I know of one option but it is not cheap. $200
Devilbiss Sri, 4.5cfm at 29psi inlet pressure. 9 1/2" fan width. This gun is classed as a spot gun but it is ideal for painting hoods fenders etc. It will atomize CC / BC /SS very very well with minimal over spray. Its not a knock off gun. Its a Pro gun.
P/N SRI-631G-10
http://www.autorefinishdevilbiss.com/main.php?p=g&id=4
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 12:33 PM
Small Touch Up Paint Gun rcm800 Body - Exterior 2 10-19-2005 05:09 AM
Is This Paint Gun OK? Kampr Body - Exterior 8 07-17-2005 08:04 AM
How to fix/prevent these bad paint results Neophyte Body - Exterior 14 06-26-2004 07:37 AM
1st painting nova33 Body - Exterior 19 06-16-2003 10:05 AM
