that type of product is used during the blocking step to help level the body contours..it is a type of filler..
Sam
painttech
what are you working with,bare metal,old finish,evercoat is good to apply
over bondo for pin holes,but only small amouts,good hand blocking will show good results,but are you working bare metal? |
painttech
first apply a good metal eching primer,a light coat is all thats needed
for a long lasting finish and to insure no mosture problems down the road expoy is good but alone wont hold up. |
Ive used the slicksand quite often, it is basically a sprayable body filler. Some guys prefer to use a 2K primer for their blocking stage, I like the slick sand because it fills better and it does not shrink like a 2K will. It just comes down to personal preference.
Polyester primer is not desirable IMHO. The best is a good grade of epoxy primer like SPI ( I do not consider PPG to be a good grade of epoxy). When applied over properly prepped bare metal a good grade of epoxy like SPI does not need an etching primer, or is it desirable.
Vince |
QUOTE
olyester primer is not desirable IMHO. The best is a good grade of epoxy primer like SPI ( I do not consider PPG to be a good grade of epoxy). When applied over properly prepped bare metal a good grade of epoxy like SPI does not need an etching primer, or is it desirable. Just wondering out loud here, but what is it about PPG epoxy that is not (good). Have been using DP for years without any problems at all. I will make it a point to order some SPI epoxy soon............
Thank you everyone
I should have given more details with my question My car is down to bare metal. I am planning to shoot it next with SPI epoxy. Then filler work. I then was going to use a high build primer , but have read some pretty good things about the Slicksand. So I was curious about its advantages if any over a high build primer |
| Quick Question, Primer Orange PEEL | jeetkunedoground | Body - Exterior | 12 | 05-26-2010 03:48 PM |
| SPI Epoxy primer question | xpsyclonex2002 | Body - Exterior | 4 | 08-21-2009 12:12 AM |
| Question about helping epoxy primer cure...... | onebadmerc | Body - Exterior | 15 | 12-20-2006 02:42 PM |
| Newbie question, and rust problems. | CDRacingZX6R | Body - Exterior | 14 | 04-22-2005 12:07 PM |
| Quickie primer question | Bluepen | Body - Exterior | 1 | 05-21-2003 05:33 PM |
