Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - newbie question
Thread: newbie question
Old 05-24-2009, 10:44 PM
001mustang's Avatar
001mustang 001mustang is offline
General Spraying
You may want to buy a 1.6-1.8 mm nozzle/needle set for your gun to spray the thicker primers; otherwise you can reduce the fan width of your 1.3mm nozzle to provide adequate atomization. You may set regulator at compressor lower than 90psi to minimize dP at the gun regulator as long as you can maintain continuous 29psi (follow paint PSI spec and gun PSI spec) to the full open gun for several minutes. If you take the dP at the compressor you have a better chance of collecting water from the compressed air in your downward sloping lines and filters not your paint.
First Pass Gun Setup:
Start with gun air valve wide open.
Providing nozzle size meets paint spec start with fluid nozzle wide open for first test spray.
Providing Nozzle to spec start with fan control wide open for first test spray.
It would be worth while to buy some cheap enamel/laquer, reducer/thinner, and a viscosity cup so you don't waste your precious dupont paints getting used to your gun.
Mix some enamel the same viscosity as your dupont paint. Get some sheet metal scrap for test sprays; paper does not work that nice. Do some 2' wide test sprays to get a feel for how fast to move your gun. Try moving your gun too fast to check atomization.
With the cheap paint in the gun you can play with fluid knob and you will get the feel of it before spraying your car.
Spraying metallic sometime results in banding. Try spraying each coat in criss cross patterns. Better check paint specs before reducing final fog coats. I believe Dupont addresses this issue in their website.
Be careful with flash times. If your film is thicker than normal in some places or the temp or humidity is off then you better error towards to much flash time than too little.
I would not touch the color base with tack cloth pre clear. If you do you better be very sure it is dry. Do tack pre base of course. Do not press on tack cloth hard enough to rub the sticky stuff on your car. Do carefully wet walls and floors often with a pump up sprayer. Do buy 2 used nebulizers and clear tubing to pump fresh air into your 3M respirator. Do plan your paint sequence before spraying. It is easy to get ugly overspray in trunk gutters and door jams if you don't plan your stroke sequence properly.
Spray one extra coat of clear on all sharp edges post base coat/pre final clear coat.
If your clear has orange peel then spray one extra coat to allow for color sanding.
