newbie with a question, stock 396 BBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2011, 04:01 PM
UNTOUCHABLE's Avatar
Hello to all the engine guru's, I have a stock 396 BBC from a 68 chevelle with flat top pistons and plan on adding some edelbrock performer rpm aluminum heads to it. The heads are 110 cc. also i was thinking about using COMP cam 284 h cam in it. Around how much power will these put out ? I new to this engine building stuff all help is appreciated. Also what would the compression ratio come out to ? thanks again.
Old 01-21-2011, 04:46 PM
DoubleVision's Avatar
Info I get says if you have flat top pistons, with stock replacement gaskets of .039 thickness and a 4.370 bore size, with 110cc chambers your compression ratio is 7.4:1 which is so low it`ll be a turd and adding more mods such as a bigger cam will only make it worse.
Old 01-21-2011, 04:51 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 with DV on this.
Cole
Old 01-21-2011, 05:31 PM
BOBCRMAN@aol.com's Avatar
As stock 396 engines never had flat top pistons. All low hp. had a domed piston yeilding a rated 10.25 to 1. 96-97cc chamber. Bore being 4.094 or so.. But a 110 cc head is not the way to go..
Old 01-21-2011, 08:47 PM
ok thanks for all the much needed info. did all 396 bbc's come with domed pistons or no they didn't ? how can i tell my exact engine specs ? Would i have to break down the engine completely or would any of th numbers tell me exactly what i have ? i have the 7 digit code if needed.
all help is greatly appreciated thanx.
Old 01-21-2011, 08:57 PM
Never mind I see I need the engine code stamping numbers. As soon as I retrieve all the needed numbers/info I'll post exactly what I have and go from there. thanx again to all fo the help.
Old 01-22-2011, 03:09 PM
1971BB427's Avatar
Yes, all 396's came with domed pistons. They were at least 10.25:1 CR and up to 11:1 CR.
Even if you ordered aftermarket pistons of a lower ratio they will still be domed with the pin located to lower CR. I rebuilt a 69 396 and changed to 9:1 CR and the TRW forged pistons looked exactly like the old 10:25 pistons. I thought they screwed up, but noticed the pins were higher to lower CR.
I agree with BOBCRMAN, don't go with 110cc heads.
Old 01-22-2011, 10:23 PM
I really didnt want to do too much internally to the engine. I wanted more so bolt-on's. Whats the best bolt-ons to make a nice running 396. Its going in a 67 impala ss thats made for cruising. I gotta turbo 350 tran sand I will change out the rear gears to what ever is best. Igain thanks for all the help I learned alot!!
Old 01-23-2011, 03:25 PM
1971BB427's Avatar
Unless you're building a race engine, I'd never consider buidling any big block for operation over 5,000 rpm's. It's just not needed or good for a big block used mainly on the street Most street driving will be used in the lower rprm power band, so building your 396 for off idle to 5,000 is the way to go.
Stick with a good dual plane intake, and a vacuum operated 750 carb.
If you don't want to get too deep into the engine then don't even change the heads, unless they need work, and then just have the stock heads gone through. I'd sure go with steel roller tip rockers, but stay with a flat tappet hydraulic cam/lifter set. Don't need much internally for a good performing cruiser, and with the right cam, intake and headers you can easily get 350 HP. Heck, the stock 4 brl. version was 325 HP, so another 25 horse is easy!
For rearend gears I'd go with something in the 3:42 to 3:56 range. The 396 doesn't need to be wound too tight cruising down the highway. I'm running 3:42 in my '71 Camaro, and it's a great highway car, with plenty of stoplight power too.
Old 01-25-2011, 07:36 PM
1971BB427 based on therecommenddations u gave me what would be a good cam and torque converter. I want decent power from it and a nice healthy lumpy idle also. I have 215. heads on it by the way if that helps any. Thanks for all the help from every one its greatly appreciated!!!!
Old 01-26-2011, 06:23 PM
1971BB427's Avatar
I'm running a 288/284 duration with .530 lift, 114 degree in my 427, and that would also be great for your 396. It's got plenty of lowend power, and good to around 5500 rpm right off idle. No special high stall converter required with a automatic.
Here's what it sounds like:
Stock carb question! Bubbas Garage Engine 2 11-03-2010 11:15 AM
Stock TH700R4 Durability Question Zeeb Transmission - Rearend 2 09-09-2009 03:45 AM
stock 350 piston question? suprstock Engine 5 01-01-2009 04:51 PM
96 to 00 5.7 Stock GM Rod Question Mustangsaly Engine 24 11-28-2006 09:23 PM
question about stock camshft oaklandfan81 Engine 3 10-06-2006 05:20 PM
