Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Newbie With A Sewing Machine - Opinions Wanted
Old 02-04-2007, 10:33 PM
horvath's Avatar
horvath horvath is offline
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
You're really fortunate to have a machine like that, man. I'm glad you're getting into it! Sewing can be a lot of fun!
You could make some boots for your brake and clutch pedals (just the brake pedal if you have automatic like me) ... I'm making boots for my brake pedal, shifter and hand brake ... these would be the easiest projects I can think of to start with and I wouldn't be surprised if, after you made a couple of boots, you just kept on going.
The boots I already have, have stainless trim rings and the vinyl is glued under the *inside* circle of the trim ring. I'm going to glue leather on the *outside* of the circle of the trim ring ... in order to do that, and still be able to access the screws to mount the trim ring to the floor, I'm going to make a slit up the front of the boot with holes punched to lace it up (like a shoe) and will do a French stitch on each side. I think this is going to look really cool; I found a nice looking black hemp cord at a crafts store that I'm going to use for the lacing.
So far, I've made a radio faceplate, a faceplate for a clock and some switches, and I covered the center (horn cover) of my steering wheel ... all are covered with moose (black) and none involved any sewing.
Next I'm going to cover the backside of the steeringwheel (3 arms) with moose (black) and then make a steeringwheel cover with elk (black). The backside of the steering wheel will require some sewing and French stitches and the steering wheel cover will only require one very simple seam (completing the circle) - the trick with the wheel cover will be punching holes by hand, all the way around on both edges and then hand-stitching the edges together for a tight fit.
These are all simple projects in terms of sewing ... although the steering wheel will present some challenges in fitting ... but the real serious job will be recovering seats. I plan on getting a pair of power seats out of a late model Caddy (or something similar) and recovering them in a two-color leather scheme.
