Newer 96 350 Block fitting to a old Turbo 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2008, 03:56 PM
Hells Workshop
OK, i have a 96 Vortec 350 sitting around, and i'm thinking of putting aluminum heads that i have (old style ones) onto this motor and put it into a 80 Camaro. I don't have a tranny yet, but it will either end up being a turbo 350 or 400. My question is will this newer style one piece seal block bolt up no prob to an old tranny. Thanks again guys.
Old 10-06-2008, 04:39 PM
GMC boogie's Avatar
Either the TH350 or TH400 will bolt up fine. All you need is the late style flexplate with the smaller bolt circle and counter weight to fit the 1 pc seal crank.
Old 10-06-2008, 07:23 PM
Why not use a 700R4 and enjoy converter lock up and overdrive?
Bogie
Old 10-06-2008, 08:17 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
I agree with both replies above..^^
If it's a 'street car' then I'd consider an overdrive trans. Many upgrades have become available for the TH700R4, making it a very good choice.
If you have some real horsepower, don't just slap in a stock TH700R4 (or any) and expect it to take the abuse. Do some research.
Best of luck.
Old 10-07-2008, 12:33 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
And... not that you asked for this advice... why not keep the vortec heads. The Vortec iron heads are light years ahead of anything factory aluminum.
Old 10-07-2008, 01:47 AM
SSedan64's Avatar
I agree, especially if they're the old L98 aluminum heads.
Also you could use a Modified TH2004R O/D trans with a hardened Stator Support & Sun Shell, Wide Band, ValveBody Recalibration kit, better/more Clutches, & if Very high HP a Billet Shaft Forward Drum.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Older Chevy Block, Newer Fuel Infection texascaraudioman Engine 1 10-05-2008 12:51 PM
Can I put a turbo 350 in place of 700r4? eric32 Transmission - Rearend 7 08-23-2008 02:51 AM
sbc 350, What would be best for short block build? eric32 Engine 1 08-22-2008 09:13 PM
Installing Turbo 350 onto Chevy small block Help ecarpener21 Transmission - Rearend 9 05-13-2003 11:17 PM
