newer center section for this rear end 39 olds sedan - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2013, 11:51 PM
does anybody know if i can get a newer center section for this rear end
or you may call it a punkin
where can i get brakes for it or wheel bearings
thanks pkmosch
Old 03-10-2013, 03:43 PM
junior stocker's Avatar
I'm thinking 39-56 were all basically the same, Pontiac and Olds; the biggest difference was in the axle spline count. One had 10 splines, the other 16, but I don't remember which one was Olds, and which one was Pontiac. There's a lot of info over on JalopyJournal.Com in the HAMB section. Butch/junior stocker.
Old 03-10-2013, 05:34 PM
Wiki Edits: 27
kanter
Kanter carries lots of old car parts but they are expensive.. I always check my Napa store first, and try an olds club-forum first . sometimes you can find pieces from later and cheaper cars that will work.
Old 03-10-2013, 05:54 PM
BOBCRMAN@aol.com's Avatar
www.northwesternautosupply.com/ .................Try these guys. i get a lot of 40-50's stuff from them.
how to properly center a rear end Fairlane Man Suspension - Brakes - Steering 1 11-10-2012 10:11 PM
rear brake lines wheels to rear end center Studedean Suspension - Brakes - Steering 4 12-23-2011 06:38 PM
How to center a rear end ? kustomclassics Suspension - Brakes - Steering 4 10-21-2006 01:07 AM
Off center rear end lakota General Rodding Tech 3 01-26-2005 01:47 PM
rear end ratio (85 or newer chevy van) chrisf67 Transmission - Rearend 2 02-27-2003 04:14 PM
