newer chevy distributer in older chevy car,what are these four plugs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2010, 09:38 AM
Last journal entry: Unpacking
hello, I've been having trouble figuring out the wiring for my distributer.
i searched the forums for this and i did see anything that could help, so any info would be appreciated
the car is a 1970 Nova (points set up)
the engine is a 305 out of a 1988 Monte SS
I'm putting a HEI distributer into the car
so my question is, there are 4 wires going in to a plug coming out of the distributer (by the vacuum advance)
do i need this?
can i just remove it?
or is there a way to bypass it?
I'm attaching a picture to try and make this easier for everyone
ID:	47245   Click image for larger version
Old 08-08-2010, 10:39 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
That connection is for EST or ESC (Electronic Spark Timing or Electronic Spark Control). I see the distributor does have a mechanical advance mechanism, so it WILL work for you, but I'd have to look at the diagram for that system to see how to bypass the ESC or EST part of it. It may work just fine with that plug just left unplugged, but I don't remember for sure off the top of my head.
Old 08-08-2010, 11:14 AM
thank you, i really appreaciate it. i wanna get this thing runnin!
Old 08-08-2010, 11:21 AM
Rickracer's Avatar
It's coming back to me just a little,
IIRC, you unplug that connector to make sure you are in base timing mode in order to set the timing, so I think it will work just fine just left unplugged.
Old 08-08-2010, 11:24 AM
i set the timing before i decided to post about this problem, does that mean it will be off?
Old 08-08-2010, 11:32 AM
Rickracer's Avatar
No, if it's running like that, you are good to go,
Old 08-08-2010, 08:05 PM
Actually, a 1988 Monte would have had a CCC distributor WITHOUT the mechanical or vacuum advance mechanisms, so this distributor wasn't original to the Monte, either. Most likely this distributor came out of a mid-1980s Chevy truck. The easy way to fix this once and for all is to just get a normal four terminal HEI module and replace the seven terminal module you have now.
Old 08-09-2010, 06:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That HEI needs cleaned up. The advance plate needs to be checked to be sure it still easily rotates on the shaft, but in general the whole thing needs to come apart down to the last rusty little piece for a thorough cleaning. Also check to be sure the vacuum can works and that the small wires from the pickup coil that go to the module are good.
If you want to run it as-is (w/o replacing the pigtail and swapping to a 4-pin module), splice the green and black wires together on the distributor side. This will bypass the electronic spark control.
YIKES!!
Old 08-09-2010, 06:53 AM
YIKES!!
i know its not a real looker haha, but i got it for 10 bucks. it had a new MSD cap and coil though. thanks for the help, ill try splicing the wires today though
Old 08-09-2010, 07:03 AM
poncho62's Avatar
Wiki Edits: 5
Why not just use a late 70s HEI.......all the advances are built in.......and they are a dime a dozen.
Old 08-09-2010, 09:00 AM
it was pretty much a matter of what i had laying around. if it dosent work outfor me i will look into finding one, or switching back to points
Old 08-09-2010, 10:15 AM
Colbalt327 was right! it started right up
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
66 Chevy truck with newer engine questions? HemmiGremmie General Rodding Tech 4 07-23-2006 06:49 PM
older block to newer roller eight90 Engine 5 10-01-2003 11:35 PM
rear end ratio (85 or newer chevy van) chrisf67 Transmission - Rearend 2 02-27-2003 03:14 PM
spark plugs 502 chevy tonor Engine 1 02-13-2003 11:52 AM
