newer sbc 350 to older turbo 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2007, 01:44 PM
Hi
I have a 92 350sbc,it"s the newer style with the centerbolt valve covers and one piece rear seal ,it has a 163 tooth flywheel. I have an older turbo 350 I know the houseing bolt pattern is the same, but what about torque converters? Will I have to get anything special,or will any one for a turbo 350 work?
Old 10-20-2007, 03:31 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I don't think they went to the new metric flexplate pattern until 98, so you should be safe.
Old 10-20-2007, 05:37 PM
how can I tell if I have a metric flexplate?
Old 10-20-2007, 06:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the LS series of engines has the different bolt pattern for the converter bolt up. The trucks started in 1999 with the LS engines.
I am not sure on the F body cars
Old 10-20-2007, 06:23 PM
my engine is from a truck (I think) what should the measurement between the torque converter holes be if it"s not metric?
Old 10-20-2007, 06:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Do you have an LS motor?
Do you know what an LS motor looks like?
Does your engine have a distributor or coil on plug ignition?
Old 10-20-2007, 07:03 PM
It has a distributer
Old 10-20-2007, 07:37 PM
curtis73's Avatar
Wiki Edits: 16
Then you don't have the metric pattern.
Even on the tiny chance you did have a mismatch of parts, you can just use a metric flexplate, or a different torque converter, but I really can't see that being the case. A 92 SBC wouldn't have come with metric flexplates.
By the way... RWD cars like the Fbody got the metric flexplate in 98 when they switched to LS1s, trucks in 99-00
Old 10-20-2007, 07:52 PM
Thank you very much!
Gary
Timing woes on SBC 350 with bigger cam. Brawler Engine 5 09-07-2007 04:33 PM
cHEV 4.3L Bore size..compare to SBC 350 (both stock) boneyard Buick Engine 5 09-25-2006 07:29 PM
700r4 Swap to a Turbo 350 humanVr4 Transmission - Rearend 23 08-02-2004 07:48 AM
turbo 350 Tissue Engine 3 04-09-2004 07:05 PM
I have a turbo 350 behind a 350 4bolt main in my 65 Imapala. It shifts into first an shepardb Transmission - Rearend 5 02-19-2004 02:41 AM
