Newer SBC blocks - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2004, 06:08 PM
GearHead69's Avatar
'70 Chevelle '70 C10
Newer SBC blocks
I am running a newer 350 block.. And compared to the older ones it is a lot different, the main thing is the casting around the lifter bores is a lot taller and wider, I run a solid roller cam and obviously I run roller lifters, the horizontal bar lifters work fine and clear the casting.. I'm wondering if I could use the "pop up" style and if they would clear the block? Thanks, Paul
Oh here's what Mortec had on my block
14093638...350...87-95...2 or 4...Roller or flat tappet cam... one piece rear main seal
Old 03-12-2004, 09:31 AM
GearHead69's Avatar
Anyone?? I have tried searching all over the internet and have found nothing, mostly everyone runs the older style block.
