newly built 350 no power off the line - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2009, 07:20 PM
someone please help. unable to power brake tires. doggy off the line but opens up at 1700 rpms and pulls to 5500rpm.
I just built a 350 2 bolt. stock pistons with 2 valve reliefs. 76 cc 1.71 heads 224/224 .450/.460 camshaft. edelbrock rpm performer intake. 600cfm edelbrock carb. timing set at 18 degrees with vac. advanced unhooked. headers. 3.42 rear end gears. th350 trans stock conveter bolted into a 1971 impala 2 door.
Do I need a stall converter or need more compression to run the camshaft.
thanks Jesse
Old 09-29-2009, 07:34 PM
techinspector1's Avatar
Wiki Edits: 326
thanks Jesse
76cc heads with flat-tops in a 350 will put you right at 9.0:1 static compression ratio, too light for the cam you have used. A cam with about 204/214 would be about right. Or....you can use the cam you have now with a much looser converter (I might be thinkin' a 2500 stall unit) to get the motor past the slushy bottom part of the rpm range. However, dynamic compression ratio will still be low at the torque peak and the motor will not perform up to its potential.
Old 09-29-2009, 07:43 PM
I have a set of 1965 58cc 1.94 valves camel humps. I want to put on but need to be rebuilt first. will these heads raise compression ratio to high for pump gas.
Old 09-29-2009, 07:44 PM
sqzbox's Avatar
My pipes are my music
Why do you have the vacuum advance unhooked? Power braking the tires is just a waste of rubber. What does it do when you take your foot off the brake and just mash it?
Old 09-29-2009, 08:33 PM
Wiki Edits: 326
Wassamatta sqzbox, you don't remember being a teenager?
Old 09-29-2009, 08:41 PM
machinist & fabricator
ITS BEEN ABOUT 20 YEARS SINCE I FIRST DID A POWER BRAKE, AND I STILL DO EM TODAY!!! BUT I HAVE WISE'ND UP AND INVESTED IN A TIRE MACHINE!!!
VACUUM ADVANCE? WHATS THAT??????WITH A 2500 STALL, DO THEY MAKE WEIGHTS THAT ADVANCE TILL 4500 RPMS?
Old 09-29-2009, 08:54 PM
ericnova72's Avatar
More for Less Racer
I would set the distributor up to add about 4-6 more advance at idle while keeping a 38-40 Total timing, and work on the Edelbrock carb. I have yet to see one very close out of the box for anything with a cam over 220 @ .050". You will need to change the accelerator pump shot and nozzle size to make it bigger volume and longer lasting, change the power piston springs to the next lighter versions, and then work with the metering rods and jets.
There is a lot to be tuned into this combo.
Was the cam degreed in when installed or not??
Then you can look into a stall converter around 2800 rpm and it will run pretty decent.
Old 09-30-2009, 04:53 AM
sqzbox's Avatar
Almost forgot techinpector1. My dad told me the same thing back then, I didn't listen to him either. One thing though, tires were cheap back in the 60's. I found a little used 30W would make more smoke and the tires would last longer!!
Definition of edelbrok carburators: The first step on the way to buying a holley!
Old 09-30-2009, 05:07 AM
when I accelerate hard WOT from a stop its doggy like to much fuel but then seems to clear out and opens up. 1700 rpms or so. when rolling around the corner and keeping rpms up a little and accelerate hard I can spin the tires. I have attempted to change carbs several times. I even put on my brothers 750 double pumper holley and runs the same as the edelbrock 600. I don't think its a carb. problem. my next steps are either a stall converter or changing heads and raising compression. I don't have a timing light to set total timing. so I put it at about 18 degree with the vacum advanced should be around 38 degree total.
Old 09-30-2009, 05:54 AM
TroyBoy's Avatar
Psychomotors
Hey,all caps indicates that you are yelling or talk like Billy Mays
Old 09-30-2009, 06:44 AM
ericnova72's Avatar
More for Less Racer
You will never get it figured out without a timing light, you have no idea where it is right now. You could be 10+ off and you wouldn't know it. Get a timing tape for your balancer and find out where you are at for initial and total advance before you just start throwing big parts at it..
Old 09-30-2009, 03:18 PM
Already asked, but, Did you degree the cam in during installation? Cam could be installed retarded, if so, no amount of parts changing will make a difference.
Old 09-30-2009, 06:28 PM
Thanks every one for the input. No I didn't degree the camshaft when installed just matched the dots. I plan on a head swap just no money left at this time. I got a set of camel humps that need to be rebuilt. thats another day though.
Old 10-08-2009, 03:24 PM
tank
weight,,, that is a heavy car... like everyone else says... cam..cam..cam... gears and a stall... or chop the roof off and take the doors off,,,lol..
Old 10-08-2009, 08:00 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Before you spend the money to have your extra set of heads rebuilt sit down and come up with a thorough list of EVERYTHING that will need to be done to those heads to bring them up to snuff. Then compare that list with the cost of a set of Vortec heads and a matching intake manifold. The Vortec heads and just about any GOOD entry level aftermarket head will outperform most old factory iron. You will be money (and horsepower) ahead by going this route if you can afford it.
350 power estiment??? zbhover Engine 5 09-21-2008 02:04 PM
350 power????? zbhover Engine 4 09-08-2008 07:20 PM
power steering pump line question cokeman277296 Engine 4 01-01-2008 03:04 PM
Intake + Carb for 305HO then to built 350 (74') leroytitman Engine 10 02-26-2003 02:35 PM
Built 350 stops making power at 5000 rpm??!! chevyelc81 Engine 2 06-11-2002 10:33 PM
