Newly Built Engine Will Not Prime - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2005, 08:45 PM
njbloodline666's Avatar
I Love VTec
I recently built a 383 stroker and put it in my car. I went to prime it up today and I had no oil pressure.
Yes, I did have the oil pump with vasalene and there is oil in pan. It is a melling high volume oil pump, and I am not getting any oil into the top of the motor. My oil pressure sending unit is on the bottom near the filter and it is also reading 0 PSI.
I am not exactly sure the direction the I installed my oil filter adaptor, but I do not think this could cause the problem... but if that could be a possibility, I would like to know. I am also priming the pump clockwise.
Old 05-15-2005, 09:09 PM
Oil Pressure
My partner had the same problem with his engine....
Builder suggested to remove all spark plugs and crank engine....
Pressure came up right away....
Didn't make any sense that the standard technique of driving the pump with a 1/2" drill wouldn't work, but it wouldn't....
Old 05-15-2005, 09:40 PM
Jmark's Avatar
Are you using the correct primer? Just a straight shaft will not work. Needs to be like the distributor. The oil passage goes around the dist housing. If you are using just a shaft and no housing, the oil will get picked up fine but dumped right down the block where the dist. goes.
Old 05-15-2005, 11:08 PM
I Love VTec
Thanks guys!!! I'll try this in the morning.
Old 05-16-2005, 04:55 AM
Hippie's Avatar
Last journal entry: HEI comparison.
I made one out of an old distributor I found in the junk. Disassemble it and cut the housing about halfway between the bottom of the main housing and the flange for the hold down. Cut the shaft off just under the head so you have enough to chuck in a drill. Place the cut off housing in the engine, chuck the shaft in a good 1/2" drill and feed the shaft through the housing and turn it until it engages the pump, then prime away.
Old 05-16-2005, 10:21 AM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
if you try it with the baffled primer shaft and you still don't have upper oil gallery pressure, suspect the main gallery plugs at either end of the block.
the blonde weasel
Old 05-16-2005, 11:08 AM
bullheimer's Avatar
NEVER use credit cards!
when i drove my primer shaft with a cordless drill i couldnt get any pressure either. when i hooked it up to my electric drill it squirted up right in my face. it has to be driven fast
Old 05-16-2005, 08:14 PM
I Love VTec
i got it primed, shaved the gear off an old distributor thanks a lot guys.
Old 06-28-2005, 02:00 PM
Roadsire's Avatar
Last journal entry: Dash mods
Texas T Oil that is.....
I just primed mine today had to get an old distributor as I was using a shaft and was only getting oil on the drivers side. the pump spins clockwise. Good luck
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
engine vibration / harmonic balancer briansansone Engine 4 11-01-2004 09:29 PM
327 question adam15425 Engine 80 10-13-2004 09:22 PM
the re-definition of 0wn3d antirice Hotrodders' Lounge 12 09-29-2003 05:14 PM
