Newly purchased GFG-670 Devilbiss - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2008, 09:41 AM
Recently purchased this new gun and LOVE it! I am by far a beginner painter and wow was I impressed.
I still need to get the gun set right and still unsure if my "atomization" is correct. Being a beginner i would like some tips for setting up the gun, so for all of you experts out there...is there a way to set up this gun to get no orange peel? When I sprayed the base coat it was barely noticeable. It flashed and looked perfectly smooth. When I sprayed the clear I have a little bit of OP. 1.3 tip for the base and 1.2 for the clear i think.
Please help me out!
Thanks in advance!
Old 11-12-2008, 01:05 PM
I love that gun too....
I have not used that many but it does a good job for the money...
I am using a 1.3 tip and slightly higher pressure (42 PSI or so) for the clear (PPG 2021) and it lays out great.
That clear is great, it will flow until it is smooth; but does not want to run... - expensive though...
Devilbiss new GFG 607 or GTi best for avoiding over-spray? grahammason Body - Exterior 0 11-14-2007 05:15 PM
DeVilbiss ATI 620 vs. 670 Plus Bad Brad777 Body - Exterior 1 11-16-2006 03:17 PM
need stock 350 chevy specs to compare to newly purchased eng olds6665 Introduce Yourself 0 09-05-2004 12:04 PM
