Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Newly Rebuilt 200 4R Start up Question
Old 05-03-2012, 02:39 PM
rick 427's Avatar
rick 427 rick 427 is offline
Last journal entry: 33 WILLYS
make sure there's 11 qts, total, in that thing,if you are running a stock converter...reguardless what that dipstick says...check the pressure then....put the car on the ground,and see how the engagements in R and D feel at that point. It should bump right into gear as soon as you move the shifter....If that all works out ok,,,then you can just pull the dipstick,and re-mark the full line where the fluid level currently is on the stick.
