next fiberglass question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2006, 12:44 PM
stea's Avatar
OK. I'm in the process of shaping my urethane foam mold for my console. I plan on using fleece for the base. What is the best way to attach the fleece? Obviously a cant staple it. Is there a certain type of glue I can use that the resin wont melt?
Old 08-18-2006, 07:17 PM
tc33's Avatar
Stuck in the 30's
Last journal entry: Where it came from and how I got there - a short Summary
I use 3M Trim Adhesive. The resin doesn't seem to effect it.
Old 08-19-2006, 12:18 AM
powerrodsmike's Avatar
Wiki Edits: 161
I like using a hot melt glue gun for just about all of my foam work.
BE different....ACT normal.
Old 08-19-2006, 06:59 PM
Stinkin_V8's Avatar
Suburbanite Member
I second the hot glue gun.
Unless you need to span any empty spaces where you haven't got any foam, I would just go straight to the fiberglass. IMHO, fleece's only use is to stretch across between edges, it's not as strong as matte and resin. I like to use the thinnest, stretchiest, cheapest material I can find at the 'Mart. Doesn't eat up as much resin and doesn't add the bulk like fleece does.
Post some pics, it sounds cool.
When life hands you lemons, ask for tequila and salt
Gap problems fender to door when front fascia installed Ripped Body - Exterior 25 03-19-2006 08:15 PM
Removing "trim bump" ini 'glass fenders S10xGN Body - Exterior 12 01-31-2006 10:47 PM
How Do You Make Things With Fiberglass? Silentlion_69 Body - Exterior 11 01-01-2006 09:05 AM
Fiberglass help for novice tyman00 Body - Exterior 1 10-20-2004 01:36 AM
Question for owners of fiberlass cars? shifty Body - Exterior 4 08-29-2001 01:57 PM
