Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Next upgrade for the money pit. A 4-speed. Which 4 Speed is the best choice?
Old 05-25-2004, 06:07 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
My choice of the TH-700R4 is for the first gear being low to lower the resistance load on the engine as it now has 171,000 miles on it.
I also like the overdrive ratio being at .70 compared to the 2004R's .67 for the same reason.
Also, there is the little fact that when changing from the th-350 to either of the OD's the speedo drive and driven gears are more easily changed in the 700, the tailshaft housing on the 2004R is NON-removeable.
Both will necessitate the proper setting of the TV cable, and torque convertor lock-up in OD for longevity.
