Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > General Discussion > Hotrodders' Lounge
  #31
Old 07-05-2008, 09:31 PM
WDCreech's Avatar
WDCreech WDCreech is offline
looking for that 7sec 1/4
re: NHRA now will run 1000' instead 1320'
posted by Rob Keller:
Taking 320' less acceleration & putting it toward stopping is not going to resolve a thing .
I think that you're wrong. Had that pass been just to 1000', Scott would have deployed the chute and shut off the fuel before the car had reached the spot that his engine exploded. Had that been the situation, he would have probably stopped long before the concrete wall, or pole to support the catch net, whichever be the case.
Old 07-05-2008, 10:45 PM
carsavvycook's Avatar
carsavvycook carsavvycook is online now
My 2 cents worth
 carsavvycook's barnstar
Wiki Edits: 3
We don't know if he was unconscious, or if he had no brakes.
This is the exact reason why I state "crap happens". No one knows at what footage an engine will blow, or a driver is going to loose control, and cross the center line, or hit the wall.
I am not "closed minded". Crap can happen at any point between the start and finish lines, no matter how long the distance is in between.
Old 07-06-2008, 09:52 PM
WDCreech's Avatar
posted by carsavvycook: Crap can happen at any point between the start and finish lines, no matter how long the distance is in between.
It was said by tuners and owner/drivers, that they tune thier cars to run 1000', and just hope that it can make the last 320' against the mandated rev-limiter, required by NHRA. As you know, a fuel engine will eat itself up when run up against a rev-limiter, thus the explosions, after 1000'. If everything is shut down, and the chute deployed at 1000', it should be a clean pass, with no explosion.
Old 07-06-2008, 11:58 PM
My 2 cents worth
Wiki Edits: 3
A very close friend of mine, Randy Walls, had his Nitro Funny Car catch fire last November, and it burned down @ the 330 foot mark. I have also seen a tire go down, from picking up debree on the track, causing the driver to loose control. "Crap can happen at any point between the start and finish lines, no matter how long the distance is in between."
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "NHRA now will run 1000' instead 1320'"
HELP , My Firebird is dead IGENFIREBIRD Electrical 29 04-23-2007 02:24 PM
how to build 454 to run propane with 600+HP? propaine rockcrawler Engine 0 03-04-2007 09:12 AM
how to run heat riser tubes? matt167 Engine 1 09-12-2006 04:49 PM
Painless Electrical in 1959 Chevy Apache Craig legacy Electrical 7 06-24-2006 11:36 AM
Should I run a 2 barrel intake? CrazyT Engine 2 12-07-2002 10:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
