NHRA Stock Car Classification, reliability? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2004, 12:37 PM
New Member
How realiable is the NHRA Stock Car Classification for trying to find out the weight of different cars?
http://www.nhra.com/tech_specs/classification/
I would appreciate if you could "test" the values with your the actual weight of your own cars.
Old 09-20-2004, 01:45 PM
poncho62's Avatar
Wiki Edits: 5
Why not just take the car and get it weighed?.....
Old 09-20-2004, 06:28 PM
New Member
Don't own any of the cars.
Just want to find a way to compare the weights since i have found no other reliable sources.
Old 09-21-2004, 08:21 AM
BOBCRMAN@aol.com's Avatar
The weights published are MINIMUM weights for each vehicle.
I used to be a Tech man for a large drag strip. Many true stock vehicles are going to be as much as 300-600 lbs heavier. Depending on the options included.
The "stock" racers tend to have to have weight added to make class.
Old 09-21-2004, 10:24 AM
New Member
Ok, but if i put it like this:
If i want to compare different cars weight, and i imagine them all without options (throw out the radio, ac, powersteering etc.) is the weights pretty much right then?
