nine inch with chevy bolt pattern - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2006, 11:52 PM
Need info on getting a rear disk brake set up for this.
Would like to buy braket then add cheapo calipers/rotors but what kind. any info is good
Old 12-05-2006, 04:03 AM
Do you already have this axle?
If so then what is the backing plate flange pattern?
What wheel bolt pattern?
If you don't already have it use GM bolt pattern ends on the housing and use all GM parts for the brakes.
You could also use ford brakes and drill the rotors for the proper bolt pattern.
Old 12-05-2006, 02:05 PM
Chevy 10 Bolt drop in disk brake conversion
I have a chevy 10 bolt with the drop in ring and pinion. It has a square plate at the end of the axle the backing plate mounts to. I would like to do a junk yard disk brake conversion. What type of car / truck should I be looking for? Thanks
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 08:19 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
Chevy truck 5 inch wheel pattern to 4 .75 musky2 Suspension - Brakes - Steering 1 05-12-2006 07:23 AM
bolt pattern changing jniolon Body - Exterior 6 08-01-2005 01:02 PM
Did Chevy change the exhaust manifold bolt pattern on small blocks? STATUTORY GRAPE Engine 7 05-13-2005 05:34 PM
