nine inch rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2013, 04:47 PM
nine inch rearend
I have a nine inch rear end out of a 1976 Bronco and apparently an early center section. There is no fill plug in the third member and so I will fill through the vent but my question is how much fluid. My books are telling me 6.5 pints. Anyone know for sure? Tim
Old 04-26-2013, 08:01 PM
big gear head's Avatar
High Performance Rear Ends
Different housings take different amounts. They are not made the same. Some are smaller in the middle and some are larger. See if you can find a later chunk and measure the height of the fill plug and put one in yours.
Old 04-26-2013, 08:44 PM
2 1/2 Quarts will be just right.
Old 04-26-2013, 09:57 PM
snkbyt's Avatar
ASE Master
Last journal entry: 52 Chevy for sale
Really, don't think I've ever seen a 9" 3rd member with no fill on the left side? Can you drill and put in a pipe plug?
Old 04-26-2013, 10:27 PM
The early 9 inch rear ends ('57 through '64) had the fill plug in the back of the housing. There was no plug in the case.
You can't just say that a certain amout will be fine for any 9 inch housing. Some have a full bowl cover on the back that will hold much more oil than the covers that are flat with a bulge for the ring gear. Some housings have a long tapered center and others have a small round center. These will hold different amounts of oil.
Old 04-27-2013, 09:56 PM
You are correct to a point ,but the last 1500-2000 9" Fords I've done in my shop in the last 30 years,took "about" 2 1/2 quarts,it will be fine at that leval.....believe me...
9 inch rearend issue 18camaro Transmission - Rearend 2 08-30-2008 01:41 PM
9 inch ford rearend martion Transmission - Rearend 4 01-22-2007 11:08 PM
9 inch ford rearend 36plymouth Transmission - Rearend 2 02-28-2006 11:23 PM
ford 9 inch rearend don alchemy Transmission - Rearend 7 10-07-2004 05:42 PM
Ford 9 inch rearend Nos Transmission - Rearend 2 05-21-2003 07:39 AM
