Nissan 300zx - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2007, 08:54 AM
New Member
Nissan 300zx
What do you think of vertical rise doors on a 1986 nissan 300zx
Old 03-17-2007, 12:02 PM
BMM BMM is offline
Im pretty tired of those doors. People around here put them on anything and everything.
Old 03-17-2007, 05:29 PM
New Member
not where im from. they are never seen
Old 03-19-2007, 03:42 AM
Silverback's Avatar
Boost Retard
2 things to consider besides just looks (they’re totally not my thing and I feel they’re overdone, but I also think they’re kind of cool):
- they’re a lot more work then you think they’re going to be, unless you’ve done a set already you’ll be surprised and you’ll learn quickly why shops charge as much as they do to “install a simple kit.” Especially if you try to make it look/work REALLY right and work out some way to hide the extended wiring…
- Most kits do nothing to reinforce the pillar structure that they attach to. That pillar was never designed to see the load of the whole door swinging on one point and a strut strong enough to hold the door up. If you want the thing to look and work well more then a couple of years consider taking that whole area apart, pulling out the welder, plasma and band saw and figure out how to properly reinforce it.
Old 03-19-2007, 07:28 AM
You are a bright dude Silver, few people think about stuff like that.
Though I have no intrest what so ever to do something like this, I love the real Lambos that have the doors open like that (the LP500 Countach was first displayed back in 1971, hardly anything new these days)
However, I have taken a good look at the hinges available to do such a thing and found them to be pretty darn impressive pieces of engineering. But as Silver says, the cowl hinge mounting point was just not designed to support the weight of the door like that. On your 300, if it has T tops or a sunroof, that weight could cause you some serious problems.
Like I said, the hinges are impressive, not that they are perfect, but that they even come anywhere near working. Which is the extent of it, they "come near" working, but they DON'T "work".
If you will notice on the Lamborghini the roof is at such an angle that when the door comes down it "lays" down into the "hole" in the body around the window. On most cars, as in your Nissan, the door "swings" into the "hole".
Soooooo, those hinges allow the door to SWING out, then Pivot UP. When closing they pivot down, THEN you have to swing it IN to the "hole". They are friggin STUPID.
Like I say, I have looked at and played with them a number of times, looking for one that actually works well, everyone I have looked at , SUCK in operation.
The door and body are always full of marks and dents where the door has hit somewhere it is not supposed to because the friggin thing is waving around like a sheet in the wind. The are a JOKE plain and simple in my opinion.
You want "Lambo" doors, buy a Lambo.
2001 Nissan Altima GXE...DTC P1126 awbazar Electrical 2 07-09-2006 04:07 PM
Nissan launches self-repairing paint x711 Body - Exterior 10 05-28-2006 11:05 PM
360Dodge in 96 Nissan P/up wiring questions rossov Electrical 4 05-03-2006 05:55 PM
interchangable engines and trannies for 1994 nissan maxima siuol012 Transmission - Rearend 1 11-20-2005 05:51 PM
300ZX with a 5.3 Vortec...? Bumpstick Engine 1 12-26-2004 09:30 PM
