Nissan 300Zx not getting fuel to start - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 08-30-2012, 10:06 PM
dalamb13's Avatar
Have a 1990 300ZX that will not crank. It is spinning over but not getting fuel-can't hear the fuel pump kicking in. any help is appreciated...
Old 09-02-2012, 06:31 PM
Wiki Edits: 27
fuel pressure test
You probably need a fuel pressure test. I had problems with cold start on a Toyota Supra, It has a cold start injector, I thought it was bad, but a new one did not help. My son drove it all summer with no problems, finally he had it tested in the Fall when the mornings were frosty. and found the fuel pump was on it's last legs, would pump enough for warm weather driving But not enough fuel for the Cold injector and regular injectors. When cold, fuel starvation.
Old 09-02-2012, 08:17 PM
LATECH's Avatar
Pump doesnt run? The airflow meter on that could be the mechanical type. It will have a door that airflows through that is spring loaded. When air is pulled through it , the door opens.When door opens, 2 point type contacts inside connect and complete the circuit to the fuel pump.
you can probe the 2 connectors at the meter with a test light, and manually move the door with your finger to check if it is powering up.
If there is no power to it, check the fuses.If it doesnt turn the circuit on, the contacts are burnt and it needs replaced.
You can cut the silicone around the cover and pull it off to look in, the 2 contacts are pretty easy to spot.
Fact is stranger than Fiction
Old 09-12-2012, 08:39 PM
dalamb13's Avatar
Thanks, Sorry i didn't reply!!! Been really busy..
Found a fuel pump fuse that was bad. Replaced it and its getting plenty of pressure from the fuel pump now. The car runs great while taking off slow.. once you get to about 3rd gear or up to 35 or so, the car will fly! But if you mash "the pedal to the medal" taking off, the car practically falls on its face! Can check the pressure all the way to fuel regulators. Pressure is excellent. It has to regulators; and thinking those could be bad. Do you think so/ Could that be a possibility or is there something else to check for. (Have checked pressure, coil packs, crank angle sensor, computer, and the mass airflow sensor----ALL help is appreciated!)
Recent Modern Electronic Engines posts with photos
300zx wont start dalamb13 Modern Electronic Engines 14 08-11-2012 08:42 PM
Nissan 300zx transmision--No reverse or 2nd/won't shift out of 1st dalamb13 Transmission - Rearend 1 05-12-2012 01:57 PM
1993 Nissan D21, how to flush 10 year old fuel out? GregUnd Engine 3 04-20-2011 11:02 PM
1989 Nissan Fuel Pump Location David Tuten Engine 2 03-27-2007 02:22 PM
Nissan 300zx camarocolton Body - Exterior 4 03-19-2007 08:28 AM
