Nissan Altima GXE belt tensions... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2010, 08:43 AM
Can anyone tell me the correct drive belt tensions or rules of thumb for belt tensioning a 2001 Nissan Altima GXE? I have the belt diagrams which show the tension check point for the A/C compressor belt at the midpoint of the belt tensioner and crank pulley. There is a threaded tensioner screw on the idler pulley...no spring loaded tensioner.
The tensioner for the alternator/water pump/power steering belt is the midpoint between the idler and the alternator pulley. The alternator has a screw adjuster for setting the tension...again, no spring loaded tensioner.
I do not have a tension gauge but can use a belt deflection guideline if one exists. My other alternative is to measure the screw length exposed on the adjusters now or count turns on the adjusters when removing or reinstalling the belts. The present tensions seem fine but the belts must be removed to do a water pump job.
It appears that the geniuses who built this beauty did not expect water pump jobs to be an enjoyable procedure! The worst pump job I ever did previously was on a Ford Taurus but that one now looks like a piece of cake by comparison. I loved those old V-8's with nice open space out front!
Old 02-12-2010, 08:28 AM
sqzbox's Avatar
My pipes are my music
That's a good question. Might be better asked to a mechanic at your local Nissan dealership. I would try that question on the service writer in the garage who will probably grab one of the mechanic's to answer you. Hope this helps! PS: the mechanic might even give you some tips/tricks to make the job easier or something to look out for.
Old 02-12-2010, 08:37 AM
Drive belt tensions...
Thank you for commenting. I ended up taking measurements of the screw length on the tensioner adjusters and counting turns. I'll check with a dealer or a local garage as you suggested to see what they can tell me.
I just finished the water pump job and it definitely restored my complete curse word repertoire back to Navy days!
2001 Nissan Altima Spark Plug Wires awbazar Electrical 5 11-07-2010 01:47 PM
Intake Manifold Gasket Nissan Altima '01 boomer57tux Engine 7 02-24-2010 06:17 PM
Nissan Altima GXE, 2001... awbazar Engine 0 01-25-2010 01:46 PM
Nissan Altima MIL Code P1126... awbazar Electrical 0 07-14-2006 07:24 PM
2001 Nissan Altima GXE...DTC P1126 awbazar Electrical 2 07-09-2006 04:07 PM
