Nissan Murano flat towing - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2010, 09:14 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
My Murano AWD isn't towable on all fours, or even using a dolly, front or rear. I've searched for a fix such as REMCO drive shaft disconnects, they only make them for RWD or FWD vehicles, the same with lube pumps.
I knew years ago there was talk about freewheeling hubs or adapters, and found a patent on them, but no suggestion they exist. Does anyone know of anything similar to make this Nissan Murano towable other than trailering it behind the motor home?
Old 12-17-2010, 01:47 PM
I work for Mazda and we don't recommend it either. I don't know if your Murano uses a viscous coupling or not, but the issue with towing lies in there.
Old 12-17-2010, 03:25 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Word from Nissan is absolutely no towing on all fours as well. I just think there has to be a fix out there somewhere.
Old 12-17-2010, 06:36 PM
I think your choices are getting down to two. A trailer that will keep all four wheels off the ground when towing, or a different vehicle.
Old 12-17-2010, 06:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Many Jeeps are flat towable as a toad behind a motorhome
Flat Towing Daytona F1 Transmission - Rearend 2 09-03-2010 07:37 PM
flat tappet to roller cam HP difference sooper Engine 12 04-20-2010 12:04 PM
